8-point sockets?
Paladin
Southern Utah
:confused: Ok, this is probably a dumb question, but what good are 8-point sockets? I can't remember ever having used one or needing one.
speed bump
Butte Montana
I like using them for taps. You also use them for male pipe plugs like the ones you occasionally run into in differentials and transfer cases. You also run into lots and lots of square plugs in industrial equipment.
PowderKeg
Little Rock, AR
Old farm equipment as well - an 8 pt and a long breaker to twist/break the heavily rusted ones off and replace with a modern 6 pt bolt/nut. :)
A rack of them also looks nice and provides filler in the drawer.
P
Paladin
Southern Utah
Well, I guess that explains why I've never needed them. I've always used wrenches on pipe plugs and t-handles for taps. Looking back, I could have used one last summer! I had a square, brass pipe plug on the exhaust of my Onan generator. I couldn't get it to budge with a wrench. I had to use a 12-pt 1/2" socket on it (it was a 7/16" plug). I guess I'll hang on to thse 8-pts then. Thanks for the education!
Fedwrench
Valley of the sun
They're used on any male square fastener. I use them on a 3/8 cordless impact to quickly lower spare tires on alot of Explorers. They are one of those tools that you may not need often but when you do, you're glad you have them.:beer:
garfunkle24
Saskatoon, Canada
Square drives are common on bearing set screws on older equipment, drain plugs etc. Also useful for driving taps and/or extractors. Some guys I know just have the 3/8" one, which is most common for set screws.
chad s
Baltimore, MD
In the 20's and 30's when square bolts were more common, they were what 12 point sockets are to 6 pt. I have used one here and there for drain plugs.
walrus
Maine
male pipe plugs
Thats what I use them for. There is one plug in what in the trade is called a crash valve or an impact valve. Without a 8 point socket getting a 3/8 pipe plug out is near impossible. I've seen more ruined plugs by dopes who don't have the right tool to do the job
jimmycrackcorn
Brooklyn, NY
You can get away with using a 12 pt socket, depending on the size of the square fastener....i use mine on pipe plugs, and since i work on heavy equipment, they use square lock bolts on the anchor pin of s-cam brakes.
