Trey T
Houston, TX
1. wired up my 60gal compressor
2. Beefing up my ceiling joists with additional 2x10x22ft SYP#2 and 2x4 spacer. Getting ready for T&G pine board ceiling. I will keep the beam spaced at ~4ft.
Rewind97
Mississippi
Made a bench and installed a shoe rack to store all my spray can on my door
lLvfa3esAwleZBoQUl9FE17U96bQU-wopGqMss3_lcsN=w631-h841-no
Now that is trick right there!!!!!
ewils35
Metro Detroit Area
Not today but a couple days ago I took my newborn son out to the garage to show him things lol. Granted he was half asleep and didn't know what was going on
LS6 Tommy
Northern NJ
Idea stolen. Now I just have to figure out WHERE I can mount it in the garage. It's such a great idea I might have to relocate some wall mounted stuff to accommodate it...
Tommy
burnedonice
Kansas City
Got my JD BC1600 brush cutter running properly again, cleaned the spark arrestor, carb and put some fresh gas in it. Ready too go again, just in time as I know my Olathe property is going to be at least knee high from the rain and hot sun we've been having. Not bad for 13 years old....that metal blade makes short work of weeds and even saplings
https://scontent-a-dfw.**.fbcdn.net/hphotos-xap1/t1.0-9/10533761_10202980509097646_3300116371918992724_n.jpg
Lord knows i need that at our Olathe office also, went out last week to get the trailer and almost couldnt find the darn trailer.
Dan in Pasadena
Pasadena, CA
....While I was doing that, this little guy flew in the garage to escape the rain, and wound up in a cobweb in the corner. Picked him out and pulled all the cobwebs off. He sat in my hand for about 2 minutes, I wasn't sure if he was hurt or not, but he finally took off and buzzed his way back to his tree outside the kitchen window where my wife keeps the hummingbird feeders.
IMAG0126 by wrfalcon75, on Flickr
Good on you for helping the little guy out. Karma, karma. I believe in it.:thumbup:
jwh
Rochester NY
Took a pile of stuff to the recycling center. Replaced the screens in the garage windows. Put mats on the shelves of the welding cart.
LS6 Tommy
Northern NJ
Laid on my back in the Malibu trying to find the accessory junction block all my GM manuals say is supposed to be there, so I can finish the optional trunk light install. One lousy plug to connect & I can't seem to figure out where it's hiding. I thought I knew these G-bodies pretty well...:headscrat
Tommy
sdavis622
Surprise, AZ
Installed new driver door master power window switch after much trouble shooting, changed oil and filter, put yakima topper on for our trip to the ocean this weekend. All on our 2002 Explorer. Forever having electrical issues! Been a good family SUV but if you don't have knowledge, patience and resources to fix all the small tedious issues explorers have you'd be screwed!
My brother had one so I usually call him first, wife's sisters husband is Ford mechanic and my neighbor across the street is ex paccar engineer so between all of us we usually figure out the explorers little quirks! [emoji482][emoji2]
Matt The Hammer
South Jersey
Rebuilt my son's Nerf Vulcan gun with salvage parts bought off eBay.
Why? I'm a nerd.
Yes, it's a chain fed machine gun that shoots those little foam Nerf darts. It got wet and the battery and motor contacts corroded badly.
mdbeck1
Norman, OK
Why? I'm a nerd.
Forget the kid. ....where can I get one. That's just cool!!
holdover
VA
excavated for a lean-to addition 12' X40' Need a place to park my two '29 model As
lhopkins04
Fuquay Varina, NC
In the process of building a bed frame... There are a couple of things that I need to do to it still. That was my after work project this week.
I unpackaged and started to put together, this.
Now I have to affix the top to the cabinets, install a switch and wire it, attach the router to the plate, and I'm ready to start using it.
TheEquineFencer
Farmville, NC 27828
I started putting the free floor jack back together. I now see why the local hydraulic repair place said they would even work on it for less than $150. Right now I have three quarts of oil in the repair, 2 free O-rings and a lot of time and swearing in the job.
Lassen Forge
Hummingbirds have good memories and are really social birds... dont be surprised if more show up; I rescued one that got trapped in our house, and within a few days the one or two we had grew to about 10. The original one... would hover by the picture windown in the front room until it saw us, do this little bounce up and down side to side and then fly off. Its friends used to do "arial combat maneuvers" off our front porch; I was kind of sad we had to leave them behind when we moved.
Amazing when you watch one go after a yellow jacket or much larger bird, you realize they're not just cute little things - they're the F-4 fighter jocks of the wild bird world!
mdbeck1
Norman, OK
WatsonComeHere: What is that? Got a link to it?
It's a version of the Incra Jig. I've got an early one and use it to make all kinds of useful wood joints. I made some Maple cradles with sliding dovetails up to 24" long.
WatsonComeHere: Mine is the early one made out of composite materials (some kind of plastic/fiberglass). I put inserts in the table top so I could remove it easily. I also found that if you have a long fence you should clamp the ends before pressing against it.
xyster101
Upstate NY
Painted the garage. Took 4 hours to put up 9 gallons of paint including moving the scaffolding around.
Then added the battens. I started to paint them, but it took too long with a roller. I will just shoot the garage again after they are all up.
Nortonscustom
Installed new tires, head/tail light package and a front bumper on the golf cart yesterday.
k-os
WI
Got the trim for windows on the garage wall cut and furred out to match up with the 7/16" OSB. Will be painting them later today.
Also got the french cleats cut from 3/4" plywood for on the wall. Will be painting these when I do the trim as well.
bodyguy16
QC, Canada
Looking good!
MScott
Eastern Ontario
I bought and erected the harbor freight 10x17' garage.
it's for the tractor and yard stuff so they don't have to be in the Behemoth.
All shovels and other long hangy **** will go there also.
$179 is a deal for the garage. 170sqft.of my real grage is regained.
Not sure where you live, but winters up here are not easy on those. First one I tried the cover cracked and ripped during winter cold. The second one, a much sturdier (I thought) version with 2" metal tubing frame collapsed under a heavy snow fall. YMMV.
