Detached garage feeder gauge
fizzog
Hi,
I am planning to run a 4 wire feeder out to my detached garage (shared neutral). I'm looking to have 4 circuits in the garage. 1x20A for about 8 receptacles, 1x15A for lighting, 1x15A for garage door openers and 1x15A for outside driveway lighting. Thinking of using a DP 30A breaker at the main house panel. Sub-panel in garage will have a disconnect and grounding rods (2).
Question: am i OK running 8 gauge copper or do i have to use 6 ga?
My garage is about 100 ft from the house and the internal run through the hose from the main panel is about 60-70 ft. So total length about 170 ft.
Thanks in anticipation.
Jim.
Edit: should have said. Will only be using hand tools, no welders or similar and lighting of course.
Aceman
Eastern Oregon
My voltage drop app says #6 copper for a 30 amp load at 170'.
If you end up running the #6, I would just install a 50 amp breaker in your main panel and then buy a main lug panel for your garage and backfeed a 2 pole 50 with a retainer kit. This backfed breaker is your main.
Or you can buy a 100 amp main breaker panel and use that instead. Most lugs will go down to #6 wire, but check before you wire it.
justsam
Penngrove, California
You do not need a main breaker if you are under 6 circuits in the garage. For convenience I would put one in since the cost is just not that much more.
Are you sure you will not have other loads such as compressor welder, etc?
wyliesdiesels
Modesto, CA
Not sure what u mean by shared neutral.....the #6 Aceman suggested will have a 3.4% voltage drop @ max load of 50a so u should be fine with that!
The ground wire would normally be #10 but since you oversized the wire to compensate for voltage drop, the ground wire should be minimum #8.
If u think u will ever have bigger tools or an air compressor, u may just want to go bigger on the feeder....
F
fizzog
By that I meant a multi-wire circuit. 2 lives, 1 shared neutral, 1 ground.
Thanks all for the replies. I was hoping to not have to wrestle with #6. I was hoping that the shared neutral circuits would effectively give me 240V and therefore allow me to use the thinner gauge due to the reduced voltage drop.
pattenp
Virginia - USA
Use can use #8 Cu for 170 feet but the VD will be 3.3% @ 30 amps, which is border line okay. But the feed should be sized based on the total loads(100% non-continuous + 125% continuous). So as long as your calculated total load is at 30 amps or less, then using #8 Cu will do. But it always seems if you do just enough, later you'll wish you did more.
wyliesdiesels
Modesto, CA
Yeah thats what I thought u meant but u had already said 4-wire feed which is the same thing as a multi-wire circuit....the shared neutral has nothing to do with alleviating voltage drop. The vd calcs i did were for 240v. The issue u have is distance.
Falcon67
Merkel, TX
After pricing 4x170' of Cu, might consider MHF 2-2-2-4 at under $2/ft most places. Overkill, but thinking total cost.
pattenp
Virginia - USA
Glad to see you suggest the MHF. There are a couple of treads where Cu vs. Al is discussed. I just didn't feel like going there again in the tread. :lol_hitti
Falcon67
Merkel, TX
LOL. Run 2" Schedule 80 conduit and then he could run air AND power with one install. :lol_hitti
