I picked this core tool up at a local Johnstone Supply. They are an HVAC supply house. Tire cores are similar to HVAC schrader cores so it works on either. It's advertised as made in USA and was only $10.
I think it's awesome because it fixes a few problems I run into. When I air my trail Jeeps tires down, I'm going from 30psi to 2-4psi. The quickest way is to pull the core to remove the bulk of the air. For some reason sometimes the core doesn't want to come all the way out. Then as I'm fooling with it the core lets go and shoots off into the sunset. Or if the core comes out I have to be careful I don't lose or drop it.
This tool grabs the stem of the core. And it does so tightly so the core never fails to come out of the stem. You can't pull the core free from the tool without pressing the release button on the top so I can't drop them or lose them.
