My New (to me) 18x28 backyard workshop
mrmatt
I've spent quite a lot of time on this forum admiring others' great work spaces and dedicated workshops while living in a townhome with a fairly small 2 car garage. So earlier this spring when the wife and I decided it was time to buy a larger single family home I was pretty excited to at minimum move into a place with a nice 3 car garage that I could turn into a decent space. Fast forward to June and we found and purchased a new (to us) home that not only has a decent 3 car attached garage, but a detached 18x28 workshop in the backyard (with a second driveway)! I was and still am ecstatic!
I've taken a lot of ideas and such from various garages and shops on this site and want to thank everyone who has contributed, figured I may as well do a write-up as well since I have enjoyed reading so many over the years.
The building is built on a treated lumber base w/ footings and is pretty much all plywood inside (floor, walls, ceiling, etc) - they would not allow the previous owner to build a permanent foundation / cement slab due to the proximity to wetland and a utility and drainage easement, probably means a hoist/lift is out of the question but moving on - it has a wood burning stove in the corner to heat it and is fully insulated, already wired fairly adequately including a 30 amp 220v circuit. Ceilings are quite high (need to measure still).
From the outside:
Plan is for this to become my general car / project workshop and build location for the mustang me and a few friends are planning to race in chump car and possibly WRL. Now that we're somewhat moved in and getting settled I've turned my attention to customizing the workshop to my liking. I'm fairly terrible at taking 'before' and 'in progress' pictures so the only real before picture I have is from the listing of the house before we purchased it:
Unfortunately the cool signs were removed, but the steel cabinets / workbench on the left and shelving on the right stayed which was great. Those cabinets were in pretty rough shape, lots of rust and paint looked pretty terrible and the top was an old formica counter top that was pretty beat up. I decided to put my two rolling 44" HF tool chests next to the steel cabinets. Just so happened they were pretty close to the same height as those cabinets with the wheels off and I never really move them around so I decided to build a new workbench over the whole works. This would give me a bench that is almost 16' long which sounded excellent. As long as I was removing the old top and moving things around a little bit I figured it made sense to paint those old steel cabinets as well. Found out they are made by Maysteel in Wisconsin, pretty heavy duty medical cabinets from the looks of it. I sanded them all down and shot them with rattle can rustoleum, far from a show quality paint job but a vast improvement over what they were.
Again not a lot of in progress shots but here's the boxes in place, cabinets painted and a 2x4 frame over the works, I used a kreg jig to make the pocket holes to screw all the supports together and glued everything as well, the bench top is supported by the steel cabinets on the left and then a couple pairs of legs on the right over the HF Boxes. I also screwed the top down to the steel cabinets with wood screws from inside the cabinets. I choose to lay the 2x4's flat as I wanted to keep the overall height a little lower, and it allowed me to better position everything to mount to the steel cabinets. I'm not at all worried about their strength in that configuration with this particular setup.
I ended up finding a deal on about 9 sheets of plywood from Craigslist ranging from 1/4" to 3/4" thick for $75 so I went with a 3/4" plywood top over the 2x4 frame. I thought about just doing some stain and poly over that and calling it good, but I came across a killer deal on about 70 square feet of solid bamboo flooring someone was getting rid of for $35. Bamboo workbench? why not! I fastened the plywood down to the 2x4's and started laying out the bamboo:
I decided to cut the first (front) row at a 45 and cut another 45 to wrap the front/sides with to give it a nice finished look. I've not really done much woodworking since high school so it's far from perfect, but for a garage / workbench it turned out pretty damn nice. I glued/nailed the very first row and the front trim boards and then left the rest of the boards free-floating, it extends back to within about 1/4" or so of the back wall to allow for expansion. So far it seems to stay put and not move around at all so if that remains the case I'll leave it as is. If it decides to shift at all I may have to pop a couple nails in the back row to keep everything secure.
BOOM Top Done!
In my excitement over how things were coming together, I forgot to cut a pass through in the front trim board for the two drawers that are overlapped on the left side steel cabinets, DOH. Going to have to figure out how to do that after the fact now.
I'm planning on using some polyurethane on a test piece of the bamboo to see how it reacts and looks. If it seems like it'll work out okay i plan to do a couple coats of poly over the whole bench top to help keep it looking good. I have an old desk mat and one of the rubber mats that was on top of the harbor freight toolbox that I set on top of the bench as work mats to protect the surface. At the end of the day though if it gets scratched up NBD, it's a garage, and I have extra that I can replace some pieces with if needed also.
With the workbench in place I mounted the cabinets I brought over from the old place over the right side, and installed my retractable trouble light right next to them. I plan to wall mount a 20" LCD under the center cabinet on the wall, and I have a PC I'll be putting out there for playing music, looking up technical information, etc.
I picked up a free standing parts bin storage jobbie from harbor freight for storing loose parts from projects and such - it was on sale fairly cheap and I stacked a 20% coupon on top of that. It's not the greatest built item I've ever seen but once assembled is fairly stable and should work just fine. I've got a plan in the works for more parts storage above it that I'll hopefully get to soon, and a 5' folding workbench is going to live next to it on the left which I'll hopefully get to finishing sometime this week:
Being we're going to be doing a fair amount of auto work in this garage, my little husky compressor wasn't really going to cut it, back to Craigslist as I didn't really have money for a brand new compressor and I found this 60 gallon 220volt CH compressor for a helluva deal so I went and picked it up. Seems to work great other than the included regulator has a leak. Going to see if I can fix that and if not will have to grab a replacement. I also grabbed a rapid air plumbing kit from Northern Tool as they had them on sale, that'll be a project for the near future. I already had a nice retractable air hose reel that'll get mounted on one end of the garage, and then I plan to have a coiled hose at the work bench as well. The hose reel in the picture actually came with the compressor, mine is nicer so I'm going to use the 'free' one in the attached garage along with my smaller husky compressor for filling tires and such.
Along with the aforementioned folding workbench, parts storage, and compressor plumbing projects I am going to work on getting the floor finished - it's a plywood floor so I wanted to do something to help protect it from fluid spills and such, I put down a 17.5' x 7.5' rubber mat that I picked up at Menards fairly cheap in the center, and will be using the knock-off racedeck flooring I had at my old place to go around that. I have quite a few other little projects I'd like to get to also (care of threads on here!) but we'll see how things go. I'll update when I get more done and try and take some better pictures as well. If you've got questions feel free to ask and I'll do my best to answer. I'll also try and be more diligent with picture taking going forward.
hoho98925
East of Seattle
MrMatt, that is a great space. I am assuming that the building floor is built on some PT sleepers? If a guy really wanted a lift you could cut out a couple sections of the floor and dig down a bit and place some concrete footers for your lift. I always liked the old wood floor shops, liked the feel. If that where my space i would find some car decking. maybe even some 3/4 and floor the entire shop with it, some nice fir or pine, with a good sealant. Keep the photos coming. Looks great.:thumbup:
mrmatt
Thanks for all the kind words, it is coming along nice hoping I'll have some time this weekend to work on it some more.
The footers idea is a great one, I'll keep that in mind. I don't really 'need' a lift just something that would be neat to have and I'm not entirely sure the space it would take is worth it but I'll keep that idea in mind down the road.
that is a nice space. How much usable storage space is in the attic?
Not a whole lot, I could maybe get a few smaller things up there if I had to but I have about a 10 x 20 room that is all decked above my attached garage since they used storage trusses so between the shop, 3 car garage, the above garage storage, etc I am sitting quite well on storage space.
Jpeezy
Nice shop, but your gonna want to isolate that air compressor from the hard concrete, some advice I received from a really knowledgable nice old guy, he said use some sort of wood or rubber or combo of both to isolate , he said he has fixed so many air compressors because they literally shake themselves to death. Thanks for sharing, love the bench!
mrmatt
Thanks for all the kinds words.
@Jpeezy - I picked up some thick rubber isolation pads that are now under the compressor (that picture was right after taking it off the trailer and putting it in the shop). I still need to bolt it down but it's in good shape now.
@Lord vader - I did keep the wood burning stove in the corner, it'll be my source of heat in the winter when we want to work on the car out there, it has a blower pictured also so should be fairly adaquate ( I hope! )
The weekend wasn't nearly as productive as I had hoped so didn't get a whole lot done. I had painted a dry erase board on the back wall so I stained some 1x3's and framed that in and then I also finished the folding workbench along the back wall:
I also got a storage rack for the harbor freight 20 bin organizers almost finished, just needs another coat of paint and I'll get it mounted on the wall:
Hopefully get some more done this week or over the weekend
