JonathanLaporte
I want to insulate the roof of my shed.
Now I'd like to know what are the risk of blocking the soffit vent?
Is there a vent in the roof ?
Probably not...most yard sheds don't have that.
Does the shed have trusses or rafters ?
Probably rafters...most sheds 12x18 or less do not have trusses, just 2x4 rafters to a 2x4 ridge beam (or similar).
Why do you want to insulate just the roof ?
Are the walls already insulated ?
Do you plan on heating your shed this winter ?
OK, you use the bottom chord of the trusses for storage.
In that case I would just place the insulation right up against the underside or the roof decking. There will be no venting, so no need for soffit vents.
IF you have a ridge vent, then you need to leave the soffits vented, place a foam vent baffle all the way up to the ridge vent, and then put your insulation up against the baffle.
Do you have photos of your roof ?
What worst could happen if these no ventilation between the deck and insulation?
Condensation on underside of roof sheathing, wet insulation, mold and roof sheathing rotting. No shingle warranty.
