FunfDreisig
- Joined
- Feb 12, 2008
- Messages
- 413
I want to install a TEMPORARY electrical service while building my garage. I have 50 Amps of spare capacity at the 200Amp Main service panel on the pole (150 Amps are dedicated to our cabin). The Garage is 200+ feet from the pole. What wire size (and type) would I need to power a 50 Amp Subpanel (i.e. a construction panel for compressor, saws etc.).? And what type of wire is suitable for exposed runs?
Background:
I'm currently running my small compressor, table saw OR slide saw off of 2 100ft long 12 ga extension cords (end to end). The extension cord is plugged into a 20 amp GFI on the pole. This setup works. BUT... the extension cord runs across the driveway requiring me to unplug every time we use the driveway. And the 2 - 100ft cords just barely reach the end of the slab.
I am planning to pull the cable under the construction driveway in sch 40 PVC conduit* open at both ends and simply run the rest of the cable over ground. FWIW I live in the country and have NO permitting/code/inspections to deal with. BUT I don't want to do something stupid
Thanks in Advance
* the construction driveway is simple road base and I have a backhoe.
Background:
Thanks in Advance
