Carl1971MGB
New Main panel - better
New Sub panel - cheaper
I have a 2000 sq ft ranch style modular home, in 2000 I had a basement built and the house moved onto it. Also have a 30 by 50 ft detached garage where my son on I work on classic trucks.
Presently there is one 20 amp circuit to the garage and one to the basement. The house has a 100 amp main panel. fed 100 feet underground from the meter with a 100 amp disconnect at the power pole (house is 500 feet from the road). There is a 100 amp breaker in the disconnect as well as a 100 amp breaker in the house panel. The house has an electric stove, water heater is propane. There's a window air conditioner on a dedicated 15 amp circuit.
The wood shop is in the basement - typical power tool loads such a Rigid table saw. No special loads in the garage - yet. Eventually a 60 to 80 gallon compressor and MIG or TIG welder
I'd like to put a 200 amp main panel in the basement and run the house panel as a sub and put a sub in the garage. To do this I would need to replace the disconnect below the meter, run new SE cable as well as buy the 200 Amp main panel. I'm concerned about the cost of this.
The other idea is to put a 6 or 12 breaker sub panel in the basement run off the main (100 amp) panel in the house. Eventually I'd put a 6 breaker panel in the garage. Not fully convinced this is a practical solution.
Or is there a third solution ? Thanks in advance for your comments.
