What do you use pry bars for?
mires
Columbia, MO
It seems like everybody here has pry bars and I'm sure they come in handy but just how often do you use them and for what jobs exactly? I am just a diyer changing oil, brakes, rotating tires and the like. I'm sure I could have used a pry bar once or twice over the years but I don't think there was ever a time where I just HAD to have it for anything.
That being said, I did pick up the 3 pc. Craftsman set for cheap the other day. The things this forum will do to a guy :headscrat
sk farmer
nd
prying.......:)
actually all most everything. bent tip bars for prying things apart, lining things up, bending things, you name it. rolling head or ladies foot for lining up and lifting or prying. the great big ones get used to move large things and doing things i am not strong enough to do. i have several that live on a rack on my cabinet, another drawer full and the big ones are leaned in a corner. one of the most used tools i have.
G_P
Central CT
You will find all kinds of uses for them. And likely save many a screwdriver from being bent or broken if you own a set of prybars.
JKady
Spanaway, WA
Prying, beating (in an area where you can't get a hammer in), removing lines on top of transmissions etc... I've got a Cornwell 8-24" 4 piece set and a 42" for bigger work, all get used regularly.
NorthSea92
Scotland
Levering down suspension arms when splitting ball joints, pushing back pistons, removing pulleys and bearing races, lining things up etc
The uses are endless
Buster21
Idaho
Just used mine today to move my alternator in place while I tightened the belt.
jakemac
New England
All of the above .......... plus using them as third hands and shims when needed. You can never have enough when you can't find one.
Ruger_556
Usually prying on stuff... Checking kingpins, moving frame and suspension parts into place, etc
zkling
Watch repair. :lol_hitti
In all seriousness, and to be honest I caved and bought the craftsman 3pc set on sale due to recommendations on this forum. They have come in handy, mostly for demo type stuff (I straightened a welded tube structure the other day with the longest one. They are a crude type of tool IMHO. Some people on here act as if they are a must have, I must be using them wrong as I don't agree. :dunno:
KMinAF
Fairview Utah
Positioning an engine when installing, all kinds of suspension work, levering heavy wheels into place, positioning heavy equipment in the shop, holding exhaust manifolds out of the way, removing oil seals, changing tires, opening damaged doors, digging a hole (my kids did that) hood prop, scraping grease and gunk off of a really old transmission, used it as a semi straight edge to scribe a line, fan belt tension adjustment, metal integrity tester i.e if I can push it through the panel its too rusty to weld, drain grate remover, drain cleaner, fly swatter (fly lived but it scared the **** out of the other worker) trunk spring torsion bar installer, seat frame "alignment" tool, temporary shelf support, radiator hose remover the uses are truly endless.
stearn786
NY
I use mine for almost all of the things already listed, but here in NY it's also really necessary to have at least a 3 foot bar for removing wheels. Aluminum or steel rims corrode from the salt and become seized to the hub face. I've needed a 4 footer and a hammer from time to time on pickup trucks. :rolleyes:
mailpup
Los Angeles
Besides what has been mentioned already, I use one for popping out drive axles from front wheel drive transmissions.
J.A.Varela
Indianapolis/Boquete
Pretty much most things I don't want to beat off with a hammer. I just cut some gussets out with a cutoff disc but couldn't get that last 1/4 inch of weld at the corner.A 25 inch bar. " TINK". DONE.
It was 3/32 iron welded to 1/8 wall 2 x 2. My 32 OZ ball peen woulda bent the hell out of it and made a mess. I buffered the tube with a piece of wood so as not to dent it with the bar.
Dis-assembly too. Taking off a valve cover, timing cover, oil plan, aligning a fender, separating a bell housing. Man. I couldn't live without them.
http://tools-from-germany.com/en/HA...-Workshop-Tools/Pry-Bars/HAZET-2166-3-Pry-Bar
AndeiH
texas
I just used one today to remove a driveshaft. I couldn't push it forward by hand but a 12" prybar made it easy. I could have used a flat head screwdriver but I didn't :).
chipper
Williamsburg, va
I scare my kids with mine....don't make me get my prybar!!!! J/k you'll know when you need them ...I like to use them to free stuck windows in my house
mires
Columbia, MO
Glad I picked up my set after all the uses you guys described. I figured this thread would get plenty of responses as I know you guys love your pry bars. I can easily see it being one of those tools you never knew you needed but not being able to live without now that I have them.
Engine
Kentucky
Another use for it is to help in rotating your tires. It makes it easier on your back to lay the pry bar on the ground, roll the tire up onto it, and lift it up to the wheel studs instead of just picking it up the hard way. You'll find lots of good uses on the car and home too.
MagnumForce
Use them to move machinery or other heavy stuff into final locations. Pulleys, sticky dies, etc, a ton of uses in an industrial setting.
burke753
Hobbs, NM
I use my 8" pry bar for pulling charge air hoses and radiator hoses, 24" is handy for lining up parts, I use it to turn engines over, lifting heavy parts, and brake jobs. and then I use my 36" for breaking things, lifting truck tires back on.
slip knot
Texas gulf coast
I used to keep a 24" behind the seat, to help lever some sense into someones head. Got a CCL so I put the prybar back in the toolbox.
Project_shadow
My 24" for tightening my v belts on the truck, lifting the tires, popping the drums off, pressing the calipers back in
Mostly general maintenance while in school
Just about anything when home
monomach
Illinois
Every day for suspension work. Can't do anything with control arms or leaf springs without pry bars, that's for sure.
General Geoff
Allentown, Pennsylvania
Prying loaded calipers off worn brake rotors. pulling control arms and motor mounts out of mounting points. Positioning alternators and other accessories on older tensioner systems. I use them almost every time i have a car off the ground.
redwrench60
East Tennessee
You use a prybar any time shits' happy where it's at. Until I perfect my Jedi mind tricks to separate parts I'll just have to use leverage and violence.
