OTC 5911 - Drain Plug PRO
woodstockva
USA
Hey Everybody :)
I just reviewed a tool that I literally use ALL the time & have never had any problems with. It's the OTC 5911 Drain Plug PRO & it makes changing oil a lot less messy & time consuming.
Basically this is a very strong magnet attached to a flexible shaft & screwdriver handle, that will allow you to unscrew a drain plug without getting oil all over your hands/arms & you wont have to go searching through a hot pan of oil for the plug.
Check out the video to see how great the OTC 5911 Drain Plug PRO actually works!
<iframe width="560" height="315" src="//www.youtube.com/embed/tRUhlmMU-Gw" frameborder="0" allowfullscreen></iframe>
rmsg0040
Toronto
Had 1 for a while now, I like it, many times I have dropped a drain plug into a pan, not anymore
bob_the_builder
I picked one up last week from my local auto parts store. Just waiting for one of my vehicles to need an oil change to try it out.
Bob
PKile
Fair Oaks, California
Looks cool, but I bet it won't work on M54 BMW engines...the drain plug on those is recessed inside a cove in the oil pan, and those little wings on the end of the Drain Plug Pro will probably run into that cove. Since 2 of my 4 vehicles have those engines, I might have to buy another DPP and grind off those wings. I'll try it first with the stock tool and see if my suspicions are correct.
PKile
Well, what do you know! I just checked Amazon and they make an OTC 5961 Drain Plug Pro kit with 4 adapter ends. One of them sans wings for those BMW drain plugs, and even a 17mm magnet for those recessed hex plugs on the Euro trannys and diffs! It's about twice as expensive at 24 bucks and change, but it should work for all my oddball stuff.
Strouty
Southern Maine
Added to my amazon wish list. Of course as soon as I did that, I saw more goodies to add.
Great video as always!
kball
SoCal
Good idea but... those non-magnetic crush washers will still fall into the hot oil unless you get lucky and they stay on the plug. Unless you're one of those nutty types that change the washer with every oil change...
jptbay
Thanks for the review. That's one tool I didn't know about and could really use.
BTW I found your delivery and speech in the video to be much more natural. One of the best ones yet. Keep them coming.
internetdude
Great video overall. You did a good job of giving a detailed explanation and also demonstration. I would recommend you invest in a lapel mic, and don't repeat yourself repeatedly ;) . The initial demo was unnecessary, could have skipped that and still got the point across. Most people have a really short attention span.
On a related note, I just found out about this tool recently on Amazon so I ordered it, now it's sitting here beside my desk. I think it will be my new favorite tool.
http://www.amazon.com/gp/product/B0054WI7CW/
ImportTuner
I've been using the OTC Drain Plug Pro since it first came out. Works as advertised except on magnetic drain plugs (drain plugs with magnet for catching particles) and on the MINI Cooper S round drain plug. The MINI appears to have tighter threads and will not turn with the round head until it is almost completely out.
Good video review though :thumbup:
Fcvapor05
Every car I've ever owned that had a crush washer on the drain plug (there's been 3 total) has included a new crush washer in the packaging with the oil filter.... so I've always changed it. Why not?
Nice review, seems like a simple and handy tool. I'll probably end up with one.
Mohawk Dave
SoCal
Super lazy idea here...cut the shaft off the handle and weld it to a hex shaft for m12 gun, or weld it to a shaft for a ratcheting screwdriver.
SASORacing
Utah
I dont know where in the hell you got those oil filters but I envy you. I cant even buy the correct crush washers most of the time.
Fcvapor05
I should have mentioned that these were all the same filter brand- Wix. 2x BMW and 1 Porsche.
The BMWs both used a cartridge element, where the filter body is a cast part bolted to the block. So there's 4 little parts to replace every time you change the filter- crush washer on the drain plug, big o-ring on the filter housing, then a little o ring and a sealing washer on opposite ends of the big bolt that holds the filter housing together. The Wix filters always included all of those parts.
franzdom
NC
I have a 330i 2003 M54 works great, no problem. I love this tool! :bowdown:
I guess the wings are no wider than a socket is.
Shadowdog500
Down the shore
I bought one last year and love it. No more burnt fingers. I keep it stuck to my 20 gall oil cart, so it is handy when I'm changing oil under the lift.
Everyone who sees it asks me where to get one.
Chris
PKile
Great - that's the same year and engine I have, mine is a 330ci. Also have a 2001 Z3 Coupe 3.0i with the same engine. I still bought the unit with the interchangeable ends, since they have a 17mm hex magnet as well. My Amazon order should arrive today!
Hootbro
Delaware
Let me guess, you do not every use a torque wrench either on anything you tighten? I mean that would totally be "nutty" to use recommended best practices.
kball
SoCal
^haha nope, not on drain plugs I don't. That would be a waste of time.....
PKile
Yep, tell that to one of our admins here at work where the clones at Jiffy Lube forgot to tighten the drain plug and it dropped out, causing her engine to seize.
Torquing may not be considered a "requirement", but if you have the torque step as part of your oil change ritual, you will be much less likely to forget to tighten the plug.
I've got a little spreadsheet on the wall of my garage, which lists oil capacities, drain plug torques, oil filter torques, and lugnut torques for my 4 vehicles. I'm much more likely to execute the torque step with the info staring me in the face.
Cheers,
Paul
Shadowdog500
Down the shore
Cheers,
Paul
Can you post a photo of this chart, I may want to make something similar.
Chris
PKile
Chris
Here it is, just a simple Word table. Could have probably been easier in Excel, but I'm more right-brain and like the look better:
Cheers,
Paul
RBailey
Dubai, UAE (Arabian Gulf)
Another thumbs up for the tool. From me. I just used mine for the first time, no burnt fingers or fishing in the used oil for the drain plug.
Cope
Houston, TX
I have two Kias, and they recommend changing the washer with each oil change; I have only had one washer fall off. I buy the filters ten at a time and get ten washers. I saw a write up on this tool and bought one a couple of oil changes ago. It is great.
