espyking83
Never used one, looking at a set. How do they stack against industrial/truck brands?
Buy something you can hit with a hammer...
Buy something you can hit with a hammer and has a hex area just below the handle.
This is a real screwdriver
http://tools-from-germany.com/en/HA...-1/5-Screwdriver-Set-with-Impact-Cap-5-pieces
I thought Ideal owned Pratt Read?
I never really understood the hex area below the handle, especially on a Phillips. If the screw is so tight that you have to put a wrench on the screwdriver, it is most likely going to cam out and mess up the screw head anyway. It would be pretty hard to turn the wrench AND hold enough pressure on the driver to prevent cam out. This is where I would use a 1/4" impact driver.
I have the SK rebrands and I like them.
This is essentially the same set but without the hex bolsters.
http://www.garagejournal.com/forum/showthread.php?t=128197
