Pallet Positioner
arroberts
Central Ohio
Good Morning keepers of all knowledge...
I am working on a project for work and trying to come up with a solution that someone here has probably been through before. We have about a dozen mailing machines that use different envelopes throughout the day. Right now the envelopes are delivered on a skid to the machine, and the operator has to pull the stock from the pallet throughout the day. As the jobs run, the level gets lower, requiring the operators to bend down and pick up the boxes.
I am looking at equipment like this.
http://www.chdist.com/product/hercules-manual-high-lift-pallet-positioner-pallet-truck-3300-lb-capacity-395562.aspx?var=90699
but it is only for open bottom pallets. Does anyone know of one that works with closed bottom pallets, ones that have a cross bars on the bottom of the rails?
franzdom
NC
We have auto leveling pallet raiser things that work with closed bottom pallets, are spring fed so they don't need to be jacked, and you can change springs on them for various size loads (not something you do often but it does make them adjustable). They work great, I think this is what they are:
atwageman
NC
Pitney Bowes?
A
arroberts
Central Ohio
Is the pallet dropped by a forklift or does it drop low enough for a pallet jack?
