6768rogues
My son has a 6 apartment house and a recent C of O inspection revealed that some of the 3 prong duplex receptacles have open grounds. I removed some from the wall and it appears that they were wired in the 1940s or 1950s (extensive renovations in that time period) with 2 conductor braided sheath wire. There are no ground wires and the boxes are not grounded. As most of the problems are on the 3rd floor, there is no way to get ground wires to the receptacles. I assume that they were originally equipped with 2 prong receptacles and at some time in the past they were "upgraded" with 3 prong receptacles without grounding the third prong.
Are the following compliant with the NEC:
1. Change the receptacles back to 2 prong and grandfather them in.
2. Provide them with GFCI protection (would have to be at the panel because the old boxes are too small for receptacle GFCIs), then label the outlets as "GFCI, no equipment ground".
3. Another landlord at another nearby house installed jumpers from the neutral to the ground at the receptacle. It fools the inspector's test, but I think it would create an unsafe condition.
My questions:
Are 1 and 2 compliant with the NEC?
Am I correct that 3 is unsafe?
A ground wire is out of the question, so any other ideas?
Thank you.
My questions:
Thank you.
