Air_Cooled_Nut
I have a 36' x 36' x 12' shop, unfinished ceiling (see attached photos). As you can see, the PO put 8' CFL and they are for cold weather (F96T12 CW HO CT). Work just fine, even when the inside shop temp gets in the mid-30s. They do provide good light even w/o a nice white ceiling. I plan to have the ceiling covered in sheet rock and when that happens the existing lights will need to come down. Since that has to happen I'm contemplating new fixtures.
I eventually plan on installing a two-post lift on one half of the shop so height/location restrictions will play a factor in at least part of the shop. I don't need top-of-the-line, ubber-expensive product. Plenty of bright, white, usable light is what I need. Currently have a single, 20A breaker for the whole shop lighting (16 tubes with a total of 15.4A consumption). All of the lights are currently wired direct, none are "plug-in" type. (The one light you see plugged in is now moved to a different circuit).
So I have an open canvas. My shop is for working, not a museum. If it's recommended I keep what I got then I can do that. If something better is out there that gives me more light for less power consumption without a huge cost then I can sell what I got. Given that, any experienced recommendations?
