Here is my nightmare "1810" Parker 203 back from the dead. It should be a "1910", but has an interesting casting mistake. I bought this on-line last March (I may never do that again with a Parker) and have many, many hours into it. It was not badly beat up, but had seen a lot of use and even though it was well greased, there was substantial wear. I'll be posting a full write up over on the vise repair thread later this weekend because this one had a lot of work done. Oh, and by the way, Kevin's finger prints are all over this vise in case you couldn't tell.
Here is the before photo from the online add. Doesn't look too bad, does it? and the price was right.
View media item 40377
Here is a list of things that had to be done.
- Spindle slop fixed with a bronze motor bushing. It had a 1/16" play side to side.
- Re-surface the bottom of the dynamic slide. It had a .025" "bow" worn into it.
- Fabricate shim to make up for the material lost on the dynamic slide.
- Fabricate shim to make up for the material lost on the static slide.
- Weld and resurface the jaws - they were worn down.
- Replace the lock down handle. The original was badly rusted and was missing a screw.
- Remove the rust and pitting on the handle and spindle knob and lock down bolt. Many hours into this.
- Replace the missing spindle knob "speed handle" set screw
Between the welding, resurfacing and shiming, getting the jaw faces back to parallel was no trivial task. A lot of measuring and fiddling. It is amazing that the screw and the nut were in really good shape. This vise was packed with grease, all hardened, so whoever used it really kept it lubed well. I think the rust came sometime after its "retirement".
Here are the after photos. The original color was black, as far as I could tell, and I planned on going with a dark green, but decided on a dark satin blue. It is not as blue as a Record, or Irwin, but still blue. I think satin is way to go on the old vises. It looks more period in my opinion. I also used an off-white paint for the lettering to make it look a little older. Yep, I think about these things too much.
There were many times that I thought this vise was too far gone and I did uncover a stress fracture on the dynamic support. It's not a bad crack, but I would never pound on this one. All in all, a learning and I'll post up the gory details on the repair thread. A special thanks to Kevin for his help and advice.
View media item 42877View media item 42876View media item 42878
