conceptmachine
- Joined
- Aug 31, 2014
- Messages
- 109
Hello,
Thank you for the info in advance. I'd like some expert opinion on what is needed for footings on a 40x60 pole building with 6" posts 8' on center. I'm in iowa so winters get bad sometimes. The ground is river bottom that has a mixture of gravel, sand and black dirt. I'm going to build up the ground about 2.5 foot so that if it floods I'll stay above it...so roughly only be about 2.5 feet deep into the original ground. Not in a flood plain however, just being cautious. What size, psi, and what method should be used for the concrete footings?
Should the posts be tied into the footing or should it float on top of it, and what's the benefit of either?
Thank you again.
Jim
Thank you again.
Jim
