insulating cathedral ceilings
2cool2hear
How would you insulate your cathedral ceiling? Rafts are 10-12 inches deep.
And if you have your house insulated and how do you like it? What would you have done differently?
sands35
St. Joseph, MI
Read this:
http://www.buildingscience.com/docu...6-complex-three-dimensional-air-flow-networks
and
http://www.greenbuildingadvisor.com/blogs/dept/musings/how-build-insulated-cathedral-ceiling
I'm going through the same thing to figure out how to insulate a currently un-insulated cathedral ceiling with a bad ice-damming problem.
Summary:
NO recessed lights or ways to create air infiltration.
Eliminate all air infiltration into the insulation pack.
Snow load dependent - put on a cold roof to keep the roof deck below freezing with a snow load.
Code is to insulate to R49 (zone dependent).
http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_11_sec002.htm
southernfriedcj
Athens, GA
Current house(in GA): R19 batts and 2" Dow board under drywall. I like it.
New house(in GA): 4" closed cell foam(R25 or so) and 2" Dow board under drywall. I hope I like it more.
In the areas with an attic it will be just closed cell foam, no Dow board.
I will also have a silver Galvalum metal roof.
I'm going for comfort. Energy savings will be a plus. I'm not concerned with "payback", although it shouldn't be too bad.
willymakeit
Springfield Mo.
In theory you need a ventilation area between the insulation and roof deck.
We used to install 10'' fiberglass batts in 12'' space to achieve this. Your local codes may require a higher R value which can be achieved with strapping and ridged foam. means and methods seem to be changing frequently anymore.
Randy in Maine
The Beach
I used high density spray foam in my unvented cathedral ceiling (in my 1968 log house), but I only had 2x6s to work with, so about 5 1/2" is all I have. If I had 2x10s, I would have sprayed all 9".
Actually though I am pretty pleased. I have radiant floor heat and the ceiling is actually a little cooler than the floor 60º/65º. Very tight and no ice dams.
yeldogt
Spray foam closed sell -- every house the last 20 years.
I don't do ventilated roofs
