Flare nut wrench torque tests?
Adam.C
Can anybody say what the failure mode was? I see torque limits. Did the wrenches slip? Break? Keep in mind the wrenches are different lengths as well. The top rated wrenches appear to be short and fat.
kythri
Lebanon, OR
Check the images from the German publication - it shows the failed end of the wrenches - bent, broken, etc.
Adam.C
Negative. Used Google translate. Snap on didn't bend. Form unverandert means "dimensionally unchanged". Not sure what the failure mode was.
kythri
Lebanon, OR
I wasn't talking translation, I was talking actual photos.
The photos show bent wrenches, busted rings, etc.
If the Snap-on wrench didn't bend/break, then it didn't bend/break.
If a particular wrench didn't bend or break, but is considered a failure, it's a reasonable assumption that it slipped.
Hiball
Missery
Come On Adam just go with it, Don't worry about the Details.
Fcvapor05
Based on the fact that a bunch of the wrenches had the exact same max value on the box end test, I suspect that number was the highest they could apply.
Monte
Germany
The snap-On wrenches reached the maximum of 240NM at the box end. The test machine could only test up to 250NM so they stopped at 240NM. The DIN norm for 13mm size is 107NM.
Monte
Germany
Like posted above the (most likely) strongest flare nut wrenches will be the Hazet "612N" series. 612 N-10 (10mm) /612 N-11 (11mm) ...
.... and the 612 N-8x9, 612 N-10x11, 612 N-11x13 and 612 N-12x14....:
toolmutt
Texas
Stanley isn't necessarily considered a top notch professional brand in the USA anymore, but they still produce and sell high end expensive tools under the Stanley name in other parts of the world.
All the Stanley tools I see anymore are made in Taiwan or China. However, I was in Ecuador a couple years ago doing some mission work on an orphanage in a small town. Ended up also doing some work on one of their vehicles and had to buy some wrenches at the local hardware/herramienta store. Ironically, their top brand was Stanley...(wait for it)...USA.
