zip tie/cable clamp installation tool
theoldwizard1
SE MI
Recommend one. This is for DIY, so please keep the cost "reasonable" or at least popular enough that I can find one used on eBay.
Jagmandave
Overland Park, Ks.
I have one of these and I can't remember where I bought it - probably HF - but it works fine up to a point. It won't pull them really tight, but it's fine for most things.....like most tools, the best one for the job really depends on the job you're trying to do with it.
Davefr
OR
Go to Ebay and search for Panduit GS-2B. They're >$200 new but good used ones show up for <$50 all the time. Once you use one you'll throw away all these plastic "toy" tie warp tools.
Bigblue&Goldie
^This is the way to go^
I bought a Paduit GTS off of ebay for $35 and it's awesome......even though it's plastic! :D
mattyrattypoo
My favorite is the Thomas Betts Ergo50. I use it everyday at work and works flawlessly. Also, made in Sweden.
Nickmm
What's wrong with using your teeth :-D
Our elec-techs have one, I'll check in the AM to see what model. Its stamped steel constructed like a stapler, but looks like a pistol grip tool as some of the others above are. Its handy.
Really though, I've never had a problem doing them by hand and with a pliers or etc. But this isn't in desktops/electronics installs, just general duty. When in the military, we had guys use these when building servers and running wire, they made more sense in that job.
p.s. heres a good start.
http://www.ebay.com/itm/Panduit-GS2...383?pt=LH_DefaultDomain_0&hash=item2c84e0d9e7
Bigblue&Goldie
Pull it tigjt with your hand and twist the excess end off with linemans or cut the end with linemans
While this works, these tools are able to get the ties tighter, and they can also get into places your hands can't. The best feature is they cut the tail flush; sounds trivial, but after you have cut the **** out of yourself on a zip tie cut with lineman's pliers, you will understand. On our race team if you dont flush cut your zip ties, you will inevitably have somebody ripping you a new ******* in the future.
Fcvapor05
I'm intrigued. Will this model get a zip tie super mega tight?
justme-
Boston suburbs
a proper zip tie tool will get the tie to optimal tension - too tight and they fail. I have used a few quality ones, unsure the brand but the one I used most looks like the GB pictured above and was likely made by T&B. Just bought a Hf one on clearance ($3) to try since I occasionally like to use zip ties as impromptu hose clamps.
scooternut
Pittsburgh, PA
My local Lowes has had these on clearance for weeks and no one seems to want the big pile of them. Wiss Cable tensioners. item #244869 $6.99, was $27.98
