HVAC guys, flaring tool suggestions
John T
What is the best 45 degree flaring tool?
I am pulling my hair out with this old flare tool I have.
Ready to buy something good quality.
Rigid?
J
John T
RECox286
South Joisey (yeah, that is part of the USA)
I got the Blue Point (Snappy's cheaper line) brake line
double flare kit which has been easy to use, and very
accurate and consistant. The anvil or pipe holder part
of the tool is what makes the difference. If the pipe
slips, you will curse the day you wasted your money.
If you really want a top notch tool, look at Eastman.
Uncle Bob
J
John T
actually, I just made a couple flares with my old tool and they came out nice, leakfree...
very careful preparation helped a LOT
deburring, filing the end and a drop of oil on the tool.
Steinmetz
Washington State
Agree. That Imperial tool should be more than sufficient to make a good flare. Most bad flares result from poor preparation.
Trey T
Houston, TX
I have the cheapo $15 flaring tools but I needed a high quality and proper flaring tool for the mini-split install over the weekend. I researched and the clutch-type are what's popular among the HVAC mini-split guys.
Very useful and inexpensive tool, $45 at United Refrigeration Inc. Other brands are selling it $100-200 each. It's night-and-day difference w/ the flaring compare to my cheapo flaring tool - perfect flaring every time.
I also use Nylog (bottle left of flaring tool) for thread sealant which was highly recommended by HVAC mini-split guys.
Techie1961
Pickering Ontario Canada
I suspect that some are having no issues with the Eastman because they usually use the size of tubing that puts the tool at the ends where the clamps are or they are flaring relatively soft tubing. You will notice that on good tools like the Ridgid, the clamping is directly at the tube size you are flaring. Look for that in a quality/well engineered flaring tool.
toplessHO
central florida
having made literally thousands of flares manually I tried every type known
Snapon Imperial Eastman Ridgid Craftsman and none works like this one.
It was around $300 which is more than alot of guys want to pony up,but does so much more than simple flares.I have no problem doing 3/8 double flares on stainless tubing.
Try that with your manual one. http://www.mastercool.com/pages/flaring_tools.html
One of the keys to making a good slip free flare is to clamp the holding fixture in the vise as close to the hole youre using as possible. This prevents the tool from spreading open and having the tubing slip.Dont use the end that is made for clamping in vise as the holding fixture will slip because of flex.Those bolts on the end will work for only very small flares.
If in the field use 2 pair of vise grips one on each side of the fixture.
The tool is high quality and made in USA.
Customer support is top notch too.
Trey T
Houston, TX
that ridgid is basically the same as mine but at a fraction of the cost.
I recommend the Ridgid ratcheting flaring tools like the 445R. They work great.
the one I posted and the Ridgid 445R w/ the clutch, lots of HVAC are moving away from the YJ 60278.
Yellow Jacket 60278. Older flaring tools are not designed to handled the pressures of R-410a systems.
double flaring tools are great but in HVAC, I don't know if it's necessary.
That $45 ones I got, it makes perfect flare
Trey T
Houston, TX
See photos attached. It just doesn't get any better than that. $45 is a really hot deal from United Refrigeration Inc. check it out! You can hoard it and sell it on eBay for profit.
