Spray Foam Insulation
rlitman
Long Island
Obligatory:
D
Dirtygrunt
And agin
D
Dirtygrunt
And with the insulation
D
Dirtygrunt
All I know is closed cell. Supposed to be 1 inch thick but actually 1 1/2 to 2 inch in some places
DEnd
Are you going to be adding additional insulation? Why didn't you go all the way to the top? What's up with the two studs near each other on the one wall?
D
Dirtygrunt
The two boards are where my brother tried to help lol and I just insulated to the bottom of the truss cause thats as high as I'm going with osb board. The roof is already done with the bubble stuff with shiny side up.
haptiq
VA/NC
Spray foam is pretty effective stuff. Rule of thumb tho you should have more insulation on the ceiling relative to the walls. I worked in a 4000 sqft steel building with an average inch of spray foam all the way around. A 115k btu kerosene torpedo on a thermostat kept it comfortable.
Andybull
NW, South Carolina
I'm about to spray foam my building ceiling, due to the fact that the bubble ceiling insulation is more of an anti condensation than insulation.
