pudgybear
while replacing the vinyl siding on the front of my house, i came across a plug that needs replacing / redoing,,,,, it is a 20amp "hospital grade" with a green dot on the front, it was just used as a outside receptable with no weatherproof cover,,,,, yes! i know that is wrong that's why i am replacing it with a weatherproof box, **** here's the kicker,,,,, the way it is wired has me stumped, i think the P.O. used just any wire he had left over, he had the black wire on the brass side - RED wire on the silver side - and the white wire on the ground screw, is this something special? i am thinking that i will go inside and find out where the wire goes and replace it with the traditional blk, white, green, i have never seen this wiring setup before IS IT SOMETHING SPECIAL ????????
