Brake caliper wind back tool set opinions?
90zcar
This weekend I have to do brakes all around on a chrysler aspen. I have usually gotten away using the little cube tool but I want to finally break down and get an actual set that has all the discs and r and l handed thread cranks.
Astro pneumatic offers a set that looks nice for around 40. Sunex also has one that's close to $60 and has better reviews it seems.
Any opinions? What are you guys using that do these every day in the shops?
CobraRed
The Astro 78618 kit is the same as Sunex 3930, and they must make Matco's BCW18 as well. All same pieces, with 45 grade steel and cromoly pins.
The black oxide finish isn't beautiful, but it works like a charm.
90zcar
I see the Matco one looks exactly like the astro one as they share the same case layout and everything. Not sure about the sunex one unless they had a different case made for theirs
ecotec
I have the HF set (it was 29.99 with a 25% off coupon). It works perfect.
I hate the Redneck Rubik's Cube tool, but they work.
90zcar
You can just "borrow" the set from your local Advanced or Auto Zone.
I don't like to borrow stuff much. I'd rather buy it once and be done.
I checked out the hf one and it seems to get great reviews
66354dream
Southern California
I got the Astro pneumatic one, it's awesome go for it I bought the kit that includes the left hand threaded turning piece and have never looked back.
cnk
Was using the cube but it didn't fit my wife's Mazda3 hatch so I picked up the HF set and it works great.
90zcar
I'm hearing more and more good on the hf kit. I also seen online on hf'a website that it has all 5 star reviews
n8n
Curtis Bay, MD
I'll bet the Astro one that has both the LH and RH threaded pushers is the same as the HF tool. I wouldn't hesitate to recommend it. Combine that with a Lang/Kastar ratcheting caliper press and you're set for 95% of your caliper piston retraction duties for the forseeable future.
Frosthy
FL
That's because it is a great kit for the money. Even at the normal price of $40, it's a great set. I've had no problems using it, done atleast 10-15 brake jobs with it.
justme-
Boston suburbs
Cube doesn't work on my town and country. I just borrow the set from the local parts chain which is the same as astro and HF with a different label for another brand. How often do you need this tool? For me even with the terrible rear brake design on the t&c I only need it for 10 min about once every 12- 18 months
90zcar
I'm gonna go out tomorro morning and pick up the hf set. I'll post some pics up then once I get it.
Thanks for the feedback fellas
OxJaw
Medina, Ohio
It's a great kit, I don't have any complaints with mine and I would buy it again.
90zcar
I visited snap on today to order something and get a 3/8" wobble. I then went out to harbor freight and picked up the kit. Came to 36 bucks with a 20% coupon. Man this set sure is nice! Can't wait to try it out. Stripped off the sticker on the front of the case and greased both adapters up real good.
ImageUploadedByTapatalk1411055142.325760.jpgImageUploadedByTapatalk1411055151.766258.jpg
90zcar
Not sure what this disc is for or how it works. There are no pins
ImageUploadedByTapatalk1411057396.841125.jpgImageUploadedByTapatalk1411057405.874447.jpg
Here's the description
n8n
Curtis Bay, MD
that's for front calipers or ones without an integral parking brake. There's better tools for that application, but you can use the set you bought with that adapter. Was nice of them to include it I thought.
rslaback
Westcentral Wisconsin
Stupid question:
I have the HF set that only has the RH thread adapter. Do most cars with rear discs use LH on one side and RH on the other or is that an anomaly?
n8n
Curtis Bay, MD
LH/RH is an anomaly, I bought the set with both but I think I've only used the LHT press once and I can't even remember on what.
90zcar
Thanks. In that case I already have the ratcheting blue point spreader that does dual piston calipers.
I actually thought of cutting the bar off that u turn by hand and putting on a nut on the end and welding it on for quick ratcheting use
d4dawg
I also have the HF set, but haven't have a chance to use it. Looks to be a quality set. I found the only made in Taiwan set at my store, all the other sets on the shelf were all China.
90zcar
Think I'm gonna cut the handle off and weld this nut on the end so I can use a ratchet
n8n
Curtis Bay, MD
I'm pretty sure the Blue Point one to which you're referring is the same as the Lang/Kastar one that I recommended earlier on in the thread. It is pretty neat isn't it? For multi-piston calipers it's the right tool for the job.
90zcar
Hell yeah I love it. So quick and don't have to bother with a big *** c clamp anymore. It is the exact one as the lang one
90zcar
Punched the handle off and bored out a nut to fit on the end and welded it on. A lot easier to use now
Sent from my iPhone 5s using Tapatalk
