Hi Folks,
I've visited GJ many times over the years and always learn something new. I just registered so that I could ask for advice about a very vexing problem.
My garage door is 8' x 16' and built like a tank; heavy wood reinforced with horizontal steel ribs. I have no idea what it weighs, maybe a thousand pounds? The balance springs (extension type) are as big around as my little finger. And yes, there are safety cables
The problem is with the sheaves (pulleys). They just don't hold up to the forces that the cables put on them. All I've ever found for sale are the crappy stamped steel sheaves riveted together around a crude shaft and loose ball bearings. Those may be fine for a 300 pound door, but they wear out after a handful of months of use. It's a fairly time consuming job to replace them and I'm getting sick of it.
I've thought of throwing in the towel and replacing the door with a modern, lighter affair, but this one is in perfect condition, and with new sheaves it runs smooth as silk. It's only when the bearings all fall out and the pulleys are metal on metal that the opener struggles and sometimes overloads.
Can anyone recommend a source for heavy duty sheaves? It's a standard door, with two stationary sheaves at the top of the door, and two attached to the end of the extension springs. I think they're all 4-inch.
Thanks in advance for any and all advice!
