Did y'all see this coming? Dremel just released a 3D printer... $1000. And I guess online design tools and libraries are in the works. Soon, this kind of stuff is going to...
let's not forget the other critical factor to this equation.....you gotta design the object in 3D CAD modeling software to begin with.
OK, I'll bite. Why would an individual have a use for this at $1,000?
One guy i know is using it to make a full size model of an water intake for a jet boat drive. The finished piece will be sent off to make an aluminum casting.
Sign me up if it's big enough to make AR uppers and lowers.
^^That. Printing AR lowers and other AR parts will be a major use of home 3d printers.
BTW making a gun at home is perfectly legal as long as you are not a felon or otherwise prohibited from owning a gun.
And this is the scary part. Anyone who can buy a printer can make the parts. I know anyone can do the same with a milling machine, but the printer takes no skill.
Criminals will just go buy a stolen gun off of another criminal before they drop 1k on the printer and then another 1k on the upper/barrel/BCG/LPK to complete the AR.
I was more thinking a couple gang members getting together and buying one. They start printing out 1911's by the hundreds for a quick 100 buck sale.
If I had one, I would print a handful of Glock style frames and then go turn them in at a gun buyback and pay off the printer and then some![]()
That's the easy part. The only thing to remember is most 3D parts are not longterm used, they are not super strong.
Nothing, unless you collect plastic frogs.
If this thing can do metal like a CNC machine then I could put it to all kinds of uses.
Not sure if there are even any plastic 1911's out there or if they can be made with plastic frames.
Remember that after buying the slides, barrels and the numerous other parts that must be made of metal they will still cost a few hundred dollars per gun to make. Criminals want the cheapest gun possible since they are very likely to just toss it away after they use it in a crime.
.So are these thing capable of working metals , or are they limited to softer materials ?
Criminals don't do background checks now They obtain stolen guns or guns gotten through nefarious means. It's why they're called criminals ! Making one would be to involved . Now they can sell a little crack or shoot a rival gang member to get a gun. EASY PEASY
How about proto typing a part, like we do with delrin before making it in metal. Be kind of nice to know that all the specs are right on before fireing up the cnc mill.
