akpolaris
Does anyone have an info on laying a layer of sand on the radiant heat loops in a cement floor. Supposed to heat the sand helping to heat the cement more evenly. It is all on top of the insulation layer of course
I believe they make plastic chairs you can use for your tubing so you can lay it up in your slab exactly where you want it.
I planned on more heat on the perimeter since that is where the cold spots would most obviously be.
does the expansion of the loops as they heat and cool cause any problems with the mesh they are lashed to??
I'd stay away from that. If it isn't recommended in a pex heating manual ,stick with known design plans. (Wirsbo) etc.
No. Keep in mind that you are just sending out 120º water out to the concrete from the heat source and it will come back to the heat source at about 90º.
If I lived in AK, I would use 3 or 4" of insulation under the concrete to keep heat out of the permafrost. What do the locals around you do?
How do you deal with it for years??
What is your opinion on using a Toyo boiler vs a on demand water heater that supplies the domestic water needs as well as the radiant heat?
The last 2 were the most informative responses, thank you. Brewchief I see you are also from a cold climate and HVAC guy. How do you deal with it for years?? What is your opinion on using a Toyo boiler vs a on demand water heater that supplies the domestic water needs as well as the radiant heat? I have a 32' X 32' shop with 16' walls, 6" slab with radiant heat. The plan is building an apartment 12' X 32' (mezzanine) in there as well.
If we install a job improperly or use inferior materials we will have to deal with warranty call backs and an unhappy customer for years to come, I have customers that I have dealt with for over 15 years.
I personally prefer using a boiler for heating and a separate source for domestic hot water, I don't like all my eggs in one basket. Using one unit for both can work if the system is designed properly.
