Wakesurfer
- Joined
- Jul 10, 2013
- Messages
- 40
Hello everyone! I am reaching the latter parts of my garage project - 75% done with 60% left to go!
I have a 30 x 45' garage with concrete finished floor that I plan to tile. I am going to check and map out any low spots in the next few days, but the floor does slope to two drains equally spaced and centered on the floor (approx 1" slope from wall to drain over 15'). I got a good deal on some lightly blemished 16x16" porcelain tiles with a PEI of 5. The tile supplier is recommending (and sells) C-Cure 907 medium bed thinset. They also recommend using a fiber mesh and epoxy kit (not sure of the brand yet) that comes in a 25' kit to mitigate the control joints. Here are my questions for those who have experience with garage tile:
1) What results have you had tiling over control joints? I have found conflicting opinions. Some say you MUST respect the joint and others say that a control joint treated with a membrane is durable as long as the movement is only lateral. The problem is that I originally was planning epoxy and the contractor cut the control joints irrespective of any tile dimensions. Also, I'm sure his lines are not 100% square!
2) How does C-Cure 907 compare to other thinsets?
3) The tile is not rectified, I was thinking of 3/16" or 1/4" grout lines - opinions?
4) I was planning on using a 1/2" notch trowel (back-buttering of course!).
5) If I can verify/correct the floor flatness to 1/4" in 10' (understanding that essentially I have two VERY shallow cone shaped slopes leading to the drains), will the lippage be reasonable using the 16x16s?
6) Any sage advice on layout strategy? I am planning a simple straight lay pattern.
Thanks in advance for ANY advice! The advice and guidance I have received on the electrical and lighting forums have helped immensely.
