Imagineering Block!!
Contract_Pilot
Vancouver, WA
Well, I have played with this a few times mostly used for fixing things or making a simple tools and fixtures. Now, Before I got it I had lots of ideas of what I could make if I only had a milling machine! Now that I have one it seems every thing I want to make required a lathe also. Or cannot think of anything usefull writers block for machining. Any ideas on cool tools / fixtures to make?
bullnerd
Jersey
Have you seen any of the machining mags? Home shop machinist, etc.. they have projects maybe youd be interested in.
Guster
Auckland, New Zealand
Machine tools complement each other. Once you have a mill and a lathe you need a welder and perhaps a surface grinder and lots of tooling. A press, bandsaws and plasma cutters start coming in handy. DRO's and CNC suddenly seem more feasible and before you know it a bigger work space is required. What is wrong with getting a lathe I ask you? :)
Also remember that with a micrometer boring head and rotary table you can actually get by doing some internal and external concentric work that you would need a lathe for. In fact they may be the only way to do some concentric features that are to large or difficult to fit on a lathe.
I got mine initially to service and build machinery, tools, paintball markers and R&D parts for the performance sailing community. Now I also make the odd RC parts and any general fabrication. I already had TIG/MIG/ARC welding, composite construction and general fabrication capability and the mills, lathes and other bits just extended it.
waggie
Upland, ca
if you haven't already: http://www.frets.com/HomeShopTech/hstpages.html
a piece of advice, get out now. while you can.
Like you, I got a similar size milling machine. Then I realized I needed a full sized machine... so i got one.
Then I needed a lathe, this time, I'm smarter... I went straight for a "full size" lathe.
then I needed tooling... lots of tooling.
oh yeah, this is all after going through oxy/ace, tig, mig, tubing bender, tube notcher...4x6 bandsaw, Carolina full size saw, then finally got a ellis 1800. Now i realize I need a 8' shear.
then I realized i needed a bigger building
