looking to run electric in my new pole building. I plan to put white tin on the interior of the building and would it be best to run the wiring on the inside of the walls or to run it in conduit on the outside? pros/cons?
Contrary to popular belief, you can run Romex in conduit as long as the conduit is sized properly. However, there's usually no good reason to do so - if you're going to use conduit, use individual THHN/THWN wire.
6AWG![]()
I wish you would tell my inspectors that lol
And you wind the prize....... ERRRRR, UHHHHM, What was the prize again??? lol
On the serious side I've always had my customers jobs inspected. It reduces my liability if anything ever goes wrong. I have tried installing romex in conduit(I didn't have any singles) and it got rejected by the inspector, I had to remove all of the romex and remove all of the sheathing before he would pass it. So going by the code for the 3 different states I've done electrical contracting in I feel fairly safe saying it is a no no. The reason is in romex there is no room for the wire to expand and contract as it heats and cools, whereas single wires in conduit are allowed extra space and more airspace to cool the wires.
Ask for a code reference.
I suppose it goes back to where local codes have to AT LEAST meet NEC local codes can be more strict than NEC they just can't be less strict. So if they wanted too they COULD decide that 12g copper wasn't enough for 20 amp, you now have to run 10g for a 20amp circuit. How the local bureaucracy interprets the NEC whether it seems right or wrong is what we have to deal with. Not whether we think they are right or wrong.
Not sure how your original post caused a flurry of Romex in conduit arguments, since you did not even mention the type of wire/cable.
Um I don't have my book in front of me but isn't #8 good for 50 amps? Sorry for off topic.
Yes as others have said it is NOT a violation but it is a pain in the ***.
As far as NM in conduit, this stuff looks like its made for that. Available with or without ground. Not sure what the difference is between this and NM is besides the stranding. But it is THHN inside.
http://www.wireandcabletogo.com/Tray-Cable-THHN-PVC/
Man! The thought of notching out all those metal panels for the boxes! No thanks!
Surface mount for me.
Are you an electrician? I don't know any electrician in the world who would let an inspector make up stuff like no romex in conduit but require a blatant code violation like stripped romex without calling their bluff.
The expansion stuff is something I've never heard before, and doubt I will again
[/b]
yeah ive never heard that one either!
P.S. Underground you can run direct bury romex but it has to be insulated against damage where it comes up through the concrete or in conduit if it comes up outside of the building.
Weve done it that way around here for years in unfinished basements.![]()
It's not legal to use it outside, much less underground directly buried or not.
I've never heard of the expansion theory either.
He said direct bury. I think one can use DB if buried deep enough with the use of conduit risers.
That's not what he said. He said Romex.
The only way to do that would be to use UF cable.
There is no such thing as DB cable.
