OverkillYJ
HOLY ****!!! Nickel wire is expensive!
OK, so I need to weld a truss to a front differentlal for a 4 link suspension. One link go3es on top of the differential truss itself. I see the best way to weld this is to preheat and use nickle wire. There must be more to it...
Also, where can I buy a 1lb roll? I am only seeing at smallest 2lb. I wanted to get a 1lb .030 roll so I would have more length to work with before welding the diff.
Anything else I should know about this? Also, the truss will also connect to the tubes and go from one side of the axle to the other. The differential house welding is more or less to prevent twisting in the space between the two axle tubes since they will provide most of the strength.
Tips appreciated.
Tips appreciated.
