So I picked up the Snap On YA642 jack for $50 I posted about last week
1320stang
Edmond, OK
https://goo.io/nJwYmJ
And since :needpics:
All I did was put it into the garage so far. I'm going to clean it up, change the oil in it. I think it'll need a kit in it though and I'm having a hard time finding one on the 'net.
The serial number is 6642V26088. Model number YA642, series A. 2 ton with a range of 3 3/4" to 20".
You have to put some pressure down on the jack for it to go up, as well as pressure for it to go down.
Once I get it working, should I leave it alone just cleaned up or should I restore it? :confused:
bmwpower
Hmmm....hard to say. Get the grime off and you may have a new finish underneath.
How do you lower the arm?? I don't see a mechanism at the bottom of the handle.
billymade
New Mexico
I'm sure it is a standard Lincoln jack rebadged oem for snapon; once the cylinder is out, you probably can id it from there or call Snapon for tech support. The parts on Snapon's website are here:http://buy1.snapon.com/catalog/parts/pro_det.asp?Item_id=12557&group_id=21744
Aside from the plunger; the parts seem relatively inexpensive through Snapon.
Standard Lincoln parts maybe cheaper elsewhere. I'm sure Elroy can chime in and help as well....
Here is a place that sells Lincoln rebuild kits/parts:
http://lincolnjackparts.com/
1320stang
Edmond, OK
When you rotate the handle, there's a small u-joint, much like a steering u-joint. You can barely see it in the second pic, this is opposed to the daisy gear like to my old jack to the left in the first pic.
I did do a search before I posted, but the closest I came up with was a model number 93642, which I'm guessing is the same thing. I also found label kits, which I took to be replacement stickers for the two on top of the arm.
The handle was a little bent, but I put it in the top end of my cherry picker and coerced it back close to it's original straightness. It still has a slight bend to it, but I think it's only noticable if you sight down it.
Speed-Racer
You may want to degrease it and try putting grease in the zerk fittings. The greased fittings could help with lowering. Really nice Jack, I would have purchased it at that price. It is well worth the effort to paint and rebuild if necessary. That is a really good find!
1320stang
Edmond, OK
My research has shown that my jack is a Series E and requires a 248949 repair kit. This kit is good for both D & E series jacks. The current jack is a C series and takes a 240530 kit. Blackhawk parts has it for $29.77 + shipping, and Ground is $9.25 to me for a total of $39.02. I'm gonna look local first as I'm not in a hurry, still trying to finish the house addition.
Here's a page on the history of where jacks are made as of 2005.
http://www.hyjacks.com/H2.HTM
I'm thinking of having most of it powder coated. It looks like the label kits are for Hein Warner models and not the Snap On model. If I don't do the labels, I may go for a color change. Hein Warner are blue and yellow.
I'm guessing Lincoln's were red with maybe a white handle like this Norco.
I don't care for the powder blue OTC.
I could go hammer tone or a veined finish. Maybe go with a chrome powder coat?
Any suggestions as far as color combos? (Not big into the color orange BTW.)
vssjim
McLean Va.
No the lincoln/Walkrs were Blue and yellow H/W were orange and white, SFA has changed the colors on the new ones.
1320stang
Edmond, OK
Well, I did some light cleanup on it, but it's further gone, finishwise.
(after and before)
(after and before)
And the U-joint in question.
Vinko
Los Angeles
Wow, $50? The idiots around here list clapped out no-name jacks without handles for $65!!! :eek:
Good find!
Yes. I've noticed this too. Everybody's trying to sell all the old **** they've got. Is anybody buying it? If not, why continue to list it at the same price? I guess if it just sits in the garage, and you've got the space, why not?
64merc
Texas
Cool jack you found there. From memory, it looks very much like the Lincoln jack I found the other day for $50 also. I plan on rebuilding it sometime. Are you sure you have the right kit in mind? I'll check the one that I bought locally this evening if I remember.
Paul_NJ
New Jersey
Where in New Mexico do you live? Years ago I lived in Hobbs. New Mexico is my all time favorite state.
Paul_NJ
New Jersey
Las Cruces, near El Paso, Tx!
I lived in Hobbs in the 80's for 3 years, working on a project with El Paso Natural Gas Company. I remember driving from Jal, NM across west to Las Cruces through some pretty remote areas. As I recall, there was a range of beautiful mountains in Las Cruces. I really loved it out there.
1320stang
Edmond, OK
LOL!!! My Allied jack died, I wore it out after 20 years of use. Took the YA642 apart tonight. Got a kit from Hiball back in 2011!!!
The ram is on the bench, looking for the instructions he sent me on rebuilding it now.
