Kevin54
MEMBER EMERITUS
Myself, I like it, and it is a plain, simple, but well executed design. I actually don't think anything else would hold as well as the Velcro. If you had some sort of a solid clip, then you would have to have more than one. You'd have one to hold the sockets, and one to hold the ratchet and or extension.
We used to use battery clips at work on a lot of our tooling to hold punches, but with something like that, you have sharp areas. Something like that would work, but then anything that is added on to the mold, also adds to the price. The component may be only a few cents, but the process to either assemble it, or add it during the injection mold process, can add dollars to the price.
What a lot of people do not realize, is that a plastic part like that is "injection molded". An injection mold is not a simple process to build, and you aren't going to find anyone to build a mold for a couple hundred. You are talking quite a few thousand for a simple mold. The more complex the mold, the more thousands that goes into it.
I think Socket has a good idea, and I think it will go over. And for starters, KickStarter is a good place to begin with. There are many items out there now that got their start at the same place.
Keep at it, and I think you will do well in your endeavors.
