Motorized Beach Bike
M G Koehler
Sunbury, Ohio
Saw this Beach bike and decided it needed to be motorized...
Engine
Kentucky
That's kind of cool. The first time I've seen a bike like that. Stick a motor on there and show us how it works.
Lippyp
Shropshire, UK
Ahh so thats what they are called. I saw a guy riding one with massively wide wheels like that around the pits at the Hot Rod Drags recently, never seen one in the UK before. Looks kinda cool but like it'd be a ***** to get moving with all that weight and drag from the wide rubber.
Stuart in MN
Minneapolis
I think they actually originated as bikes for use in the snow - I see a lot of people using them for commuting in Minnesota during the winter. Look online for a Surly Pugsley bike.
gte718p
They are getting to be fairly popular around here for beach riding. Quite a few ways to do it, what is your plan?
Personally I would just go with the hub motor and call it a day. That is not for everyone though.
M G Koehler
Sunbury, Ohio
Here is the motor kit for a motorized bike. it is designed for a skinny tire bike so it will take some fab.
It is Made in China but surprisingly not bad quality
Bighead38
Rockland County NY
Gonna have to follow this closely because I would love to put a motor on mine. Are you upgrading from the coaster brake?
Here's mine fresh from the store:
After a little clean up:
M G Koehler
Sunbury, Ohio
Got to add some cool "lighting" holes in the rear sprocket
and
modify the brake arm
jd_1138
NE Ohio
There's even a trike version.
Might be easier and more practical to do a friction drive system where you simply have a lever that you pull up or down to raise/lower the engine on top of the front tire.
zkling
That is awesome, one of my favorite color schemes.
The rolling resistance on payment must be hell !
They are typically geared pretty low on the front. Not designed for high speed road cruising. Especially the fixed gears.
kerrynzl
Tauranga, New Zealand
Why don't you get one of those Chinese electric bike conversions.
you lace the electric motor hub into the existing wheel.
They're quite quick, I nearly got flattened by one when I was living in China.
Lippyp
Shropshire, UK
The one I saw had little red reflectors all the way around the inside of the wheel rims like the one in post #13. Was cool cruising around the pits but I can't see it as a practical everyday bike.
M G Koehler
Sunbury, Ohio
Laying out the motor position - and cutting the frame - the motor needs to be off set a bit to clear the tire. Frame cuts easy with a sazall and a fine blade
theoldwizard1
SE MI
Maybe it is the angle of the picture, but it looks like the pedal crank arm is going to hit the engine crankcase.
M G Koehler
Sunbury, Ohio
Fab'ed up a bracket to fit in the frame out of 1/4 x 1 3/4 crs and welded it in place -
bulletpruf
San Antonio
I'm in Beijing now. Electric bicycles are everywhere. Must outnumber mopeds/scooters/motorcycles 20:1.
