Hello everyone, I'm new to this board!
I have a question in regards to the mini-split charging process. I've been rather very thorough on the entire installation. However, one thing I was not expecting was an issue I had where I tightened the nut a bit too much, and it broke off the 1/4 copper flare and I lost the pre-charged freon.
So, I got additional r410a and checked beforehand to see if I still had any additional R410A by opening the valves, and with having a pump and such ready at my side. However, there was no additional freon left so I got another r410a canister and after watching countless videos, and viewing many posts from professional and diy'ers on the process, Im sure I have it down.
I did my calculations, got my scale, weighed it all in and it was going fine, I did the charging in bursts so that I would not overflow the system too quickly with liquid refrigerent. However, my max capacity that is labeled on the air conditioner 84.7oz (5lb 4.7). It was going good until after reaching 3lb (1.3oz), where it acted like as if it did not want to add anymore, it was extremely slow, only adding .1 oz more of regrigerent every 5-10 seconds, if that. So I shut it off to come here and ask for some help.
According to the unit, I should be able to fill it up to 5lb 4.7oz, but I've only got 3lb 1.3oz atm inside the unit, any suggestions at to why it slowed down, is it actually topped off already and I somehow missed the "additional" r410a that was somewhere in the unit/compressor that caused the rest of it to not completely leak the first time around?
I should mention, the unit said that it comes with refrigerent enough for 15 feet of lineset, however, I do not have 15 feet of lineset, I've more along the lines of 10-11 feet (if it was laid flat and not curved like an L on the wall). Is this potentially the reason why it stopped filling because I have a shorter amount of lineset then what the unit originally came with?
Thanks.
Thanks.
