Aluminum AN Wrenches ??
Crawlin
NC
I have two, that I got from Summit Racing. All they say is summit on them, so I have no clue who makes them. They have been great so far.
mag99
tuttle, ok
Don't be tempted and buy that AN-adjustable wrench! My buddy bought one, after a couple of uses, it marks and chews the fittings just like a steel wrench.:(
The jaws wont stay tight enough, and since they are aluminum, they slip and round themselves, and spread like this ^.
Get summit, or speedway grade or better if you can afford to.:beer:
WVU Tuba Dale
Morgantown, WV
I just wrapped the jaws of a steel wrench with some masking or 'lectrical tape and it seemed to work fine for me. You could try that if you only have a few fittings to do. :)
W
Weedwaka
Yeah, the adjustable aluminum units look like a bad idea.
I want to get a good quality set but Snap - on wants 250 cdn . I wonder who makes their kit ??
Anybody use Joe's brand ?
nissan_crawler
Wichita, KS
I have never figured out why people feel a need to get aluminum AN wrenches, when there isn't a single one in a hangar of 500 jet mechanics.:headscrat
Plain and simple, they're a gimmick.
engnerdan
Minnesota
You aircraft mechanics may not be using them but are you TRYING to not mar the finish on the fittings you work with? I think these wrenches are for people building cars they are planning to show or want to look nice, and they do not want a bunch of nicks and **** in there anodized AN fittings.
-Dan
W
Weedwaka
How do you guys keep the fittings from getting ugly with standard wrenches ?
I need to keep under hood fittings etc looking perfect. :beer:
W
Weedwaka
-Dan
What he said . Im a fussy pants.
garfunkle24
Saskatoon, Canada
Do not over torque and use a clean undamaged wrench , this is why weekenders need the Al wrenches.
I think you're wrong. Even with a perfectly clean, unworn wrench, I don't think you could torque most fasteners to spec without leaving any markings whatsoever. I'm talking concourse show quality here. Any wrench that had close enough tolerences to not mark a fastener or AN fitting whatsoever would have to be a press fit that you beat onto the fastener. Which I'm pretty sure would mark it.
But the electrical tape idea would work fine.
jeffj78
TX
Been using an adjustable wrench (Crescent) for years on AN fittings with no markings whatsoever. Hold the wrench steady, tighten the wrench, tighten the fitting. Not that difficult.
nissan_crawler
Wichita, KS
-Dan
If we were damaging fittings, we wouldn't be allowed to use them. If they're getting nicked, quit jacking up your wrenchs.
What's the difference between a steel wrench with no burrs, and an aluminum wrench with no burrs?
If you have good wrenches, it won't damage the fittings at all. Well, assuming proper torque. For some reason many people with cars and such insist on using retard torque on all the fittings, even though planes have flown for years with half the torque on them.
voidifused
Canada
I run into them the Rare time at work, never had an issue with the right size wrench that's clean so long as you take care when working on it. I think people get them for the pretty color's
-B-
Northshore of Boston
You are joking right the fittings are not that soft in fact you will find brass fittings to far softer. I have never had an issue in marking them up it only happen with over torquing that they become marked.
rsanter
visalia ca
for a show can where you so not want to mark up the fittings, buy the aluminum AN wrenches.
for the race cars we never used them.
one thing you can do is get some aluminum sheetmetal and cut strips that will fit inside a slightly larger wrench. basically you are making soft jaws for a wrench
bob
paramudduck
ohio
Thanks folks, I had seen those things floating around. Always wondered why they were made. Well now I guess I know!
Does this mean I have to quit using my MAC long patterns and buy some of them?
paramudduck
ohio
Don't feel stupid. It was a good question. But like any other you will get a lot of divergent opinions.
If you're working on a show car and don't want to have the slight extra worry they may be useful. I've used my Macs on race cars for a while and never seen any real damage from not using the AN wrenches.
The aircraft guys work on them all the time with very strict requirements. They just use the regular one as well. But ultimately it's up to you and what you want. They do look pretty in a open roll in the trunk at a show...
jtrace
Piscataway,NJ
I have I think its an 8 pc set maybe 6 I don't recall (had a meeting tonight with Jim Beam lol) I got them years ago from a guy on Long Island getting out of racing. Got a set of scales a bead roller, the wrenches, turntables,caster/camber gauge,toe plates tire pyrometers and whole buch of other stuff for I think it was a grand. I use them but don't think I would have them if I didn't get them in the package deal...
John
crashbumper
Gilbert, AZ
I just put some tape in the normal wrenches and thats it. None of the fittings look ugly, and they are all black summit brand fittings. I thought their anodizing would be substandard compared to Earl's, Russell or Mr. Gasket but none have any noticeable signs of damage.
:dunno:
nightrain00
I don't know about air craft but the buses I work on use all sorts of AN fittings but they are steel not aluminum. They also clearly arent anodized and no one cares if they get marked up. Maybe that is why they make the wrenches from aluminum?
