The Hallowell and other low temp "boosted" heat pump products are very interesting. However, properly installed geothermal is pretty much unbeatable for efficiency. Most comparisons that make non-boosted air source heat pumps look almost as good as geothermal are not using the most efficient geothermal units (ie, WaterFurnace Envision series) in their comparison.
Rick, 35° is a very reasonable switchover point for a dual-fuel system, but keep in mind that you are in Kentucky. Much north of there, even into central MO, IL, and IN you might go weeks during the winter without ever getting above 35°, getting no benefit from your heat pump at all.
I am shocked
at the cost of bore holes for some areas compared to central MO. I have seen others state costs like $10k per 300' hole, like Rick. That is pure insanity for geothermal bores. Here, I could have any one of 3 or 4 drillers come in, drill a 400' water well, case it 200', install a 1-1/2 hp pump, pipe it to the house, install a 60 gallon pressure tank, controls, and all wiring, and not be to $10k yet! And yes, they will be in limestone before they get down 10' most places.
The going rate for vertical geothermal loops here is $1500 - $1600 per installed ton. Local practice is to drill one 150' hole per ton, so for 6 tons of capacity, I would get six 150' bore holes, with HDPE loops installed and grouted, all header connected, heat sealed connections, and the headers trenched to the house and run into the basement, all loops pressure tested, flushed, purged, and filled with 30% PG, for about $9000.
I've been doing a lot of research into geothermal, as we are looking to build a new home. We have at least 3 HVAC contractors and 2 well drillers within 35 miles that have been doing geothermal heat pumps for 20 years or more, so that helps.
Also, for those of us thinking about geothermal, osama obama's stimulus package just did something really good for us. There was an existing tax credit for 30% of the cost of an Energy Star compliant geothermal heat pump system, capped at $2000. The stimulus bill signed into law on 2/17/2009 removed the cap for any system installed after 12/31/2008 - so its a straight 30% tax credit (NOT deduction) for the entire cost of the system. Therefor, a $20k geothermal system would in effect cost $14k. More details here:
http://www.dsireusa.org/library/inc...US37F&State=federal¤tpageid=1&ee=1&re=1
