EricBigNally
- Joined
- Jul 29, 2014
- Messages
- 22
Great, now I have to go get one... Thanks for the video!
am i the only one who thinks this was a stupid thing to do. i am glad you broke a ratchet in a vise with a pipe. it proves you can break anything with a pipe. oops, i may get another timeout for not being a sheep.
How many teeth are the HF pro ratchets?
ps. i am neutral on most things. not a snap-on nut job or harbor freight-ite. i think they are fine ratchets but this kind of thing just rubs me wrong.
looks pretty good but that thing was flexing a lot! Flex is wasted energy.. I'm pretty surprised the drive rounded. I would have thought the rat. mech. would strip..
I'm impressed! I'm a Snap On Dual 80 guy, but I would find it pretty funny if one failed easier than the HF!
I still won't be buying any of the HF ratchets as I think they are too bulky, but they appear that they will hold up to some serious ****!
More than that probably, he is at least.... 250 ish, and probably pretty strong by the looks of it. The bar is 2.5 to 3 feet long? To generate 600 ft. lb. he would only have to be exerting 200 pounds to the bar... At least 900 to 1200 ish..
The ratchet was plenty strong enough! lol.... Good show!
Great job on the test. Ratchets are not designed to break bolts that are torqued to that extent. That is what a breaker bar is for. For this ratchet to be able to still function and handle all that is pretty impressive considering the price. Try that with a Sears Crapsman and the shrapnel will probably kill you, your neighbor and his dog!
So when you are breaking loose U-bolts, cross members, hitches, and lugnuts...you don't want to know if your ratchet is going to hold up? You don't want to have any confidence while using it?
How's your plastic ratchets working for you?
All conjecture... this guy actually put one to the test. How many would satisfy you? 5? 10? Send the guy 10 ratchets and I'm sure he'd be happy to test them for you.my plastic ratchets? i have no idea what that means. i don't own any. i do have the new composite and it has worked well in the limited use i have given it. i do think there is a design flaw in them but that comment got deleted.
do i abuse my tools? i try not to break things and i am not proud of it when i do but i did break 3/4 drive proto and sk ratchets trying to remove a flat from my kenworth. it caused me to get a 1 inch drive earthquake impact but that is another story.
as far as i know i am still able to have my own opinion, even here. all that the test showed me is what happened with his . what will happen with the next one? how about the third one? how many in ten would take it. there is variability in everything. there is also a failure rate and you never know what it it is until it fails and that point often varies from item to item. confidence comes with time and experience.
and the comment about useful posts? these new harbor freight ratchets have been the king of causing useless posts. page upon page of useless posts about coo, brand and who know's what and you pick mine to call useless.
thanks for all of the respect.
Nobody said this is the be-all, end-all. It's interesting is all... far from useless. I'm not gonna go down this path of negativity with you... enjoy your journey.conjecture.....an opinion formed on the basis of incomplete information.
hmm. seems to fit pretty well here.
it doesn't matter how many would satisfy me but it is quite apparent that one is more than enough to satisfy most people.
and why should i send him ten ratchets? i didn't ask for the test. is the criteria that you can't make a comment unless you buy one for the test? if so then lots of other people should not comment either.
the op said he didn't have enough money to buy a snap-on. he apparently has enough money to buy the hf and test it to the point of ruin. does he have the money to buy a second one now or do we just turn it in under warranty?![]()
I have a couple craftsman I could do it with too lol
I think the vid should be sent to SNAP-ON....Just to be fair...If they want to continue down the ching-chong path. So they can see what they will be up against for $24.
Thanks for taking the time and making the effort to test these. I guess now I'm convinced enough to buy them. I wouldn't even think of putting that kind of stress on my Proto ratchets.
Thanks again for making this video dgxlh!!!!I have a couple craftsman I could do it with too lol
Kudos to OP for making the video. I agree that flex is wasted energy, so total torque is impossible to determine in this case, but the point that he took it well beyond normal use and abuse is valid.
To prevent the broken head and better simulate real-world use you need a scrap socket clamped in the vise, maybe with flats ground on it, or welded to angle or channel and then clamped in vise.
If OP proposes more testing I'm sure a board member (sure, I'm volunteering) could make you a fixture from an old socket if you don't have welding or machining capability. I'm thinking mill 2 flats on either side of a socket.
I bought the short handle 1/2 inch, but where would the long handle be helpful?
I can't imagine its size being easy to get into a lot of tight spaces, and shouldn't anything that requires that much leverage to break loose be broken loose with a breaker bar?
