I have all copper plumbing in my basement and it has been there for a while. As a result, many of the water shutoff valves are corroded and stuck open. It hasn't been an issue, but I'd like to deal with it before it is an issue (i.e. I need to shut off the water quick!).
What would be the best way to fix these stuck valves so that I can turn them again? Could I use a torch to heat them? Should I cut them out and put a Sharkbite valve in place (Sweating copper is not an option!).
For reference, the valves are the old style metal circle like you would see on a hose bib outside.
Thanks,
Robert
Thanks,
Robert
