Outdoor lighting timer not working....
MagicMarker
Ok. I've found the timer online, but it isn't tripping the lights on/ off. It's a Paragon Timer model 4000. It is attached to a switch. I can manually turn the switch on/ off and it works fine. But when I leave the switch on, the timer works, but the trips don't turn the power on /off.
I just bought this house and figuring out the quirks. Please tell me what you see and if you have any ideas.
and what the heck is that little box over/ attached to the switch box?
The Cobbler
does the manual switch in the timer work the light?
does the clock face turn when it's powered on?
That little box above is a light sensor
the lampcord wired into your boxes is scary.
MagicMarker
Not sure.. I guess I haven't tried that yet.
Yes, the clock turns when the light switch is off/ on.
That little box above is a light sensor.
Interesting.. why would there be a light sensor inside the garage?
Agreed... you should see the other wires. It's pretty terrible. I'd really love to have an electrician to come in and fix a bunch of things, but I really love to get this timer working.
jhelrey
MN
You can buy a new one at Menards. Are you on the correct day for it to turn on?
alfredeneuman
Fullerton, CA
It could be a weak clock motor.
To test it, don't manually turn the switch on for about an hour past the scheduled time.
If you check, it will still be set at the scheduled time after an hour, and too weak to trip the dogs on the timer
alfredeneuman
Fullerton, CA
If there was a conflict between the timer and photocell, you wouldn't be able to turn the lights both on and off manually.
The photocell could have nothing to do with the timer.
I still can't figure out why you'd want a photocell in the garage.
cybrdyke
USA
It's possible that the switch can override the photocell. Like my post light with a photocell, no matter what time of day or night, I can control the light via switch.
Agreed, that's weird. I'm gonna stay with my theory that you have 3 controls, (switch, photocell, timer) and that they aren't, or cant be, wired correctly to do what you want.
Scrap them all and put an in-wall timer in place of the switch. Or scrap the switch and the photocell and let the timer do it's job.
CD
Zeke
Open up the switch box and take a close up and pull the switches out to reveal the wiring. Power off, of course. Maybe the photo cell is switching the transformer for some reason. You know that the clip is there to block the sensor, right?
alfredeneuman
Fullerton, CA
CD
It's very unlikely the timer is meant to override the photocell. That would be self defeating. Anything is possible though, given this setup :lol:
It's usually a switch like the two below the photocell used for overriding the photocell.
The transformer on the right of the box may very well be some sort of low voltage lighting, hence the lamp cords coming out of the bottom of the box.
Mustang51js
Haskell nj
It's a 240 volt timer. Replace it with a 120volt timer. The clock isn't spinning with just 120v hooked to it or e motor went bad
MagicMarker
I'll have to open up the switch and show you guys the mess the previous owner created.. It's kinda scary what people think is OK to do.
404
Mass
People die in house fires because of jacklegs like your previous owner.
Previous owner of my house used masking tape instead of wire nuts inside boxes..
Guy nearby wired his basement outlets with lamp cord and then put up studs and paneling. Argued with me that it was just as good as using the proper wire.
That lamp cord insulation can get brittle and fall off the wire.. also screw terminals on switches are for solid wire only.
If that was my house I would look in every outlet and switch box to see what other treats were inside.
Good Luck,
Regards,
404
Mustang51js
Haskell nj
Personally I would get an updated timeclock and replace it,they are about $50. Something must be broken off that moves the switch on and off, or someone put in wrong pins
MagicMarker
Good Luck,
Regards,
404
I think I'm just going to have an electrician come out and correct it.
Of course while messing around in the house, I found that one of the sump pumps isn't working. It makes noise when I trip the float, but no water is ejected... ugh.. home ownership.
Charles (in GA)
50 mi south of Atlanta
Try the switch inside the timer, it is the silver lever just below and to the left of the dial, with the down pointing arrow stamped into it. It slides left and right to operate, the on and off trips on the dial should also make the manual switch lever move on and off.
Charles
404
Mass
I hope it works out not too expensive for you.
One gets used to home ownership.. it gets fun after a while.. basement spring flooding.. winter pipes freezing... roof replacement.. It has made me into the person I am today.
:lol_hitti
MagicMarker
Charles
Tried that and nothing happened. Do I just try to replace the guts of the timer or replace the whole unit to something digital?
MagicMarker
:lol_hitti
I have a plumber coming out next week to replace the sump.
I'm sure that I'll enjoy the house more once some of these little issues are fixed.
Cmreschke
North of Detroit
Question about the lamp cords, are these lights your operating low voltage (12-24 volts )?
If so that wiring is pretty standard for those lights thinking landscape lighting. If this is the case maybe check that the transformer is working. Are you able to turn the lights on and off with just the switch?
404
Mass
Oh it certainly is better than renting, or being in a condo. You are master of your domain. Sorry if it sounded like I was against houses, I was serious when I said sometimes it is fun dealing with challenges.
Regards,
404
