2 inch conduit s bend
justin1795
blue grass IA
started trenching for my garage wire. the wire will come down the foundation and into the ground. my problem is the footing sticks out about 8in from the brick foundation. I can use some 90's but I think it may look tacky. I thought there would be a premade s bend but I don't see any. I watched some conduit bending videos but nothing large on 2" pvc
Aceman
Eastern Oregon
Use 45 degree bends to kick it out pass the footing.
Exactly. I usually start the offset as tight to the footing as I can to try and keep as much of it underground as possible. Ideally, all I want to see when I'm finished is a straight pipe going down into the ground. I'll usually take a small sledge and bust the corner off the footing as well just to get a little more out of it.
kingchevy
Just take a torch and heat up a section of pipe, I use a HF weed burning propane torch on all my conduit. Put it on the ground and roll it while you are heating it and in a few minutes it will soften like soft spaghetti. Then you can lay it in place to conform to all of your bends. Hold it till it cools and be sure to check that it stays round until it cools. Some people will plug the ends of the pipe first to help keep it from collapsing.
Syberia
Perris, CA
I've always been told to stay away from direct flame because it heats the conduit too quickly and will burn it. I've bent plenty of 1/2" using a heat gun but never anything larger. If you're careful not to collapse it you should be fine; you can cap off the ends and fill it with sand to be sure.
Sent from my Tricorder using Tapatalk
Flexia
Akron/Canton Ohio
Use your grill to heat up the conduit! Makes it nice and soft and it's not direct flame so it won't burn. You just have to make sure you manually turn it.
astroracer
Mid_Michigan
I used the oven but the grille would work. Had to put a shallow "S" bend in some 2" to hook up the garage addition back in '96...
Mark
bjcouche
I like the propane weed burner idea. Most of the plastic conduit I bent during my shop build would not have fit in the oven or grill. I bent lots of 1" and 2.5". I used a heat gun on the 1" and a propane torch on the 2.5". A weed burner would have made the 2.5" much easier. The trick is to heat the conduit gently and evenly without melting it. If using a propane torch or weed burner, you don't want to get the flame too close and you always want to keep it moving along the conduit, never stopping in one place or you will melt that section. It should not be discolored or blackened. Another tip is to not heat or try to bend at the end of a section. Heat and bend 1 foot or so from the end and if you need the bend closer to the end, wait until it cools completely and then cut to length. By not heating right to the end you help maintain the round shape. Also heat a slightly longer section than you actually need to bend, as you'll find that it's less pliable near where you stopped heating. If you try to bend it and it's starting to kink, stop, it's not hot enough or not heated completely through yet. I'd practice on a couple pieces before working on the critical one you need. Using one of these methods takes a little time and patience but it can be done. I usually try to set it on a large workbench with a form set up to the correct angle. Then when holding it on the form (with welding gloves) I blow compressed air through it to cool it faster. Once it's holding it's shape I stop the air and let it cool to ambient before trying to cut it.
If you are doing a lot of bends, there are professional tools designed for this task. They are a tube shaped oven that the conduit slips through that evenly heats the conduit all around.
Brian
The Cobbler
an electrician friend with whom I've lost contact with, used to rig up his van exhaust with a garage exhaust hose to bend larger pvc conduit. used to be able to work with it like a pc of cooked spaghetti after running the van for a while
LEVE
On the Willapa
IIRC, you're limited to how many bends you'll have the run. It can't go over a total of 270* for run.
I had this problem and had to install an underground box and break/splice the line in the box.
zmaxmotorsports
South of omaha
Not more than 360* between boxes,although 270 would definitely be nice in some situations!:lol:
rlitman
Long Island
Holy **** that's GENIUS!
