that's what I thought, until I learned about heat pumps.
All "resistance" heaters are 100% efficient, but there is another way to produce heat from electric that is far more efficient. It's a heat pump. A mini split heat pump will generally be 2-4 times as efficient than resistance. They lower efficiency when it gets colder outside.
If any of you plan on using it substantially, I highly suggest one if you don't have gas.
If you do have gas
Just throw in something like this
http://www.alpinehomeair.com/viewpr...uWKTopt5WDdZEJidh-OXfA7KkLMa0CRq6ghoCY4Xw_wcB
The duct work can literally just go up, make a 90 degree bend, and then straight across the ceiling and you cut a few vents in it. I have no thermostat, just one of the turn style light timers, I just turn it to 30 minutes before I get in and the garage is like 75 degrees by the time I get in there. No insulation, no nothing. There is no cheaper and easier way to heat a garage.
