Checking out the Milwaukee Drill/Driver kits today and it seemed the M18 Fuel Hex driver was physically smaller than the M12 hex driver. If so isn't it best to get the M18? More power and able to fit into tighter spots.
I only saw the tools without batteries on display. I did not know the 18v battery was so much larger/heavier. Is there a small 18v Fuel battery available? That would be cheaper than getting a 18 & 12.
I can break off hex drives with 12V if I can get enough grab with it, any torque beyond breaking bits isn't really accomplishing anything.
As to 1/4" hex to square drive adapters, you MUST make sure you are getting impact rated, Irwin, DeWalt and Harbor Freight sell both impact and non-impact versions, and the non-impact will snap or the hex will peen over and will become jammed in the tool's chuck, a lesson I've learned the hard way.
TheGrooveking
I had an M18 drill for a bit, and decided with 4.0 batteries on it, it was just way too heavy for my needs. You can get an M12 hammerdrill too. I have one, and it works fine for me... I don't use the hammer every day, but I do all the building maintenence at work in a concrete block building, so I needed something to drill into the walls. The M12 impact also has "drive control", it's just only got 2 modes. The lower one is like ~12 ft./lb., I love it for times when I can't get a hand in there to start a bolt/nut by hand. With that little torque, it'll start hammering right away if it tries to cross-thread. Also works great for running on pan/valve cover bolts to torque by hand.I do like the compactness of the M12 line but the M18 isn't much bigger or heavier. I'm looking at the 2791-22CT kit that comes with the smaller 2.0 batteries (I already have 2 of the XC 4.0 batteries). The M18 driver also has 3 fastening modes (i.e. "DRIVE CONTROL" which the M12 doesn't) so you don't have to worry about over torquing anything
Them M12 Fuel driver is more than adequate. The M18 batteries are all larger than the normal M12 batteries.
This is a timely thread as I too want to get a new Milwaukee Fuel driver\impact driver kit and can't decide between the M18 and M12?
I already have an M18 Fuel Impact Wrench with 2 XC4.0 batteries. I like that the drill in the M18 kit is a hammer drill which means I can use it to replace both my current M12 drill and my corded Milwaukee hammer drill.
I know me, which ever way I go I'll end up wishing I had gone the other way but I'm just not seeing any compelling reason to go M12 other then save a few bucks?
Cost is not a factor. Its more of a matter of deciding which one is more appropriate for my needs? The M12 has size and weight on it's side. The M18's have power and capacity on their's.If cost is a factor, have you thought about getting an adapter? Milwaukee makes square drive to 1/4" hex adapters, so if you have an m18 impact wrench you are happy with already, you could use it to pull double duty
