Can you answer this question?
6768rogues
Western NY
Plaster of Paris is a good suggestion. You can also consider cementitious mixtures with tiny aggregate. Maybe something like sand mix combined with type S mortar, to have small aggregate and the plastic working qualities of mortar. A couple of bags won't cost much and you can experiment.
D
daddycreswell
Middle Tennessee
could you use plaster of paris?
I used Plaster of Paris for my first mold, I just wondered if I made it from concrete if I wouldn't have to be so careful with the mold. I treat the plaster one like a child and try not to crack it.
wnstwolf
New York and PA
not sure what your end game is here but could you look at West Systems and use an epoxy or fiber glass? once cured they are quite strong and you could then fill it with low expansion open cell spray foam and have a pretty solid shell/mold?
I could be way off for what you are after but thought I would thro it out there
D
daddycreswell
Middle Tennessee
My end game is to vacuum form R/C bodies from that mold.
Freejack
St. Peters MO
I don't think you'll want to use a cement but rather epoxy or some sort of polymer.
I think in some cases Araldite iron filled epoxy resin is used then pass back over it with a void filler. I have seen that done in smaller 1/24th scale slot car bodies.
Jake
sac02
Yes, why not some sort of polymer perhaps? I don't know much about molding R/C bodies and what type of polymer they will be made of, but my first thought was polyurethane, it is easily moldable and available in any durometer you can ask for. Or epoxy may have less potential for interaction with the r/c body?
404
Mass
Long story short I am looking to make concrete molds of RC bodies. What type of concrete can I use that is smooth when dry? Thanks
Non Shrink Grout. There are versions at HD and Lowes. Can be mixed with water to ratios where it is a flowable liquid and still set up. Or use less water for a stiff mix if you are sculpting like clay.
Are there going to be holes in the mold to pull air thru? Am unclear on the method you are planning on.
Regards,
404
tncatadjuster
Memphis, TN
Leaflessshadetree
Don't ask.
What about using foam (maybe even low expanding foam) to make the shape. Then a skim coat of epoxy or fiberglass resin. Sand to a smooth finish.
D
daddycreswell
Middle Tennessee
Regards,
404
No there are no holes in it. I want to make a mold of the body pictured.
Sent from my dumb apple products my work makes me use.
Strouty
Southern Maine
What is the final product going to be made out of? Are you trying to make a hard shell like Tamiya has or are you just trying to customize things?
D
daddycreswell
Middle Tennessee
For the final product I will be vacuum forming lexan over the mold.
