Seems that everyone here is jumping on the Lithium-Ion wagon. If you need "MORE POWER" and use your tool everyday I can see it. But these Lithium-ion packs only last 2-3 years. If you can afford to get a new drill every couple years fine. Many can find better use of their resources by getting a NiCad drill or tool. Less upfront expense. Twice the useful life of the battery. Cheap to solder new NiCad cells in a battery pack and go again for another five years. It is dangerous to solder Lithium-Ion cells so you have to get a new battery pack or as most know it is about the same cost to get a whole new drill. Tell me where I'm wrong as I'm about to get some new Sub C cells ($6-$12) and rebuild my NiCad pack. Unless there is a reasonable Lithium-Ion strategy.
http://www.ehow.com/facts_5939109_lithium-batteries-vs_-nicad-batteries.html
"Nickel-cadmium batteries can be stored or used for up to 5 years. Lithium-ion batteries can last for anywhere between 2 and 3 years."
http://electronics.howstuffworks.com/everyday-tech/lithium-ion-battery2.htm
"Lithium-ion batteries age. They only last two to three years, even if they are sitting on a shelf unused. So do not "avoid using" the battery with the thought that the battery pack will last five years. It won't. Also, if you are buying a new battery pack, you want to make sure it really is new. If it has been sitting on a shelf in the store for a year, it won't last very long. Manufacturing dates are important"
