Is that stout enough to function as a breaker bar? It looks beefy enough but I'd be worried the ratcheting mechanism would fail.
It's been good so far. I wouldn't call it underpowered because it pumps the grease just fine. Just takes a little longer than the big shop air powered one. Not a whole lot longer but to properly do a u-joint for example takes a good 15 seconds of pumping. A fine trade off in my eyes for the portability and ease of use. Plus it's my own so it's always clean unlike our shop unit which is...Post up how that grease gun works for you. Been eyeballing one if I go back to working on trucks. Better than wrestling a roller can and air hose around.![]()
But of course. Can't fall a sleep, so I've been playing with the camera
All the drivers, including the lonely Kobalt
Branding Difference on the Gearwrench drivers
The "Family"
Few other pictures of the sets as attachments, don't want to take up too much screen real estate.
~ Carson
Heated hoodie from Home Depot, 3/8 fuel impact and a long flex head snap on ratchet that I scored from a pawn shop.
It's been good so far. I wouldn't call it underpowered because it pumps the grease just fine. Just takes a little longer than the big shop air powered one. Not a whole lot longer but to properly do a u-joint for example takes a good 15 seconds of pumping. A fine trade off in my eyes for the portability and ease of use. Plus it's my own so it's always clean unlike our shop unit which is...![]()
where did you geth that sk set in the uk?
IMO that space looks like they just molded in a compartment for keeping odds in as the box was a bit bigger than it needed to be, you see this quite often.
How much you want to bet some old timer modified a set of automatic wire strippers to separate air lines and someone else made a lot of money off of it?![]()
Oh it's been a good couple days.
Where did you get those ratchets and screwdrivers? I like......a lot....
I rarely post in this thread, but i got some new mac precision torque sockets.
Had them a week, and love them.
Yeah, a little to blurry.
Great chrome on the outside, satin(ish) finish inside.
All over good sockets.
I have an almost identical scraper from KD. Might have to look into the replacement packs of those plastic blades. I could see those being pretty useful if they work well.
