What is the best way/tool to cut Racedeck tiles?
D Defender90 Member Joined Sep 14, 2014 Messages 11 Nov 3, 2014 #1 What is the best way/tool to cut Racedeck tiles?
J James-W Well-known member Joined Feb 3, 2013 Messages 12,432 Location Southeastern Wisconsin Nov 3, 2014 #2 I have never done it, but from what I have read you can use a sharp utility knife. I have read that a table saw works really well.
D dubber Well-known member Joined Dec 31, 2012 Messages 5,326 Location Canada's Capital Nov 3, 2014 #3 Skill saw, the more teeth the better for a clean cut. And cut with the tile upside down. Just cut nearly 40 tiles this past weekend.
OP D Defender90 Member Joined Sep 14, 2014 Messages 11 Nov 3, 2014 #4 dubber said: Skill saw, the more teeth the better for a clean cut. And cut with the tile upside down. Just cut nearly 40 tiles this past weekend. Click to expand... What are you using? Table saw, chop saw?
D dubber Well-known member Joined Dec 31, 2012 Messages 5,326 Location Canada's Capital Nov 3, 2014 #5 Circular saw.
J James-W Well-known member Joined Feb 3, 2013 Messages 12,432 Location Southeastern Wisconsin Nov 3, 2014 #6 I would think a circular saw would be more difficult to use for cutting tiles than using a table saw or a chop saw would be.
S Splitpi Active member Joined Sep 19, 2013 Messages 32 Location Sachse, TX Nov 3, 2014 #7 Regarding which way to cut ... The old adage from wood working are: use a high tooth count blade Visible side up on a table saw (the table saw cuts on a down stroke), Tearout will be on the bottom (non-visible portion) Visible side down on a circular saw (The circular saw cuts on an up stroke), Tearout will be on the top (non-visible portion) use a zero clearance baseplate on either the table saw or circular saw.
B bymbie Active member Joined Aug 17, 2013 Messages 26 Nov 3, 2014 #8 I did my floor a month ago. I used a jigsaw with a plastic blade (i had to cut around my woodstove hearth pad). Worked like a charm.
C Croixboy Active member Joined May 28, 2014 Messages 37 Location Lewes, De Nov 3, 2014 #9 A tablesaw works great, especially if you need to take like 1" off a bunch of tiles down one side of the garage. I picked one up off craigslist and put a new blade on it. I would be happy to pass it along for $30 if your in the mid-Atlantic area.
D dubber Well-known member Joined Dec 31, 2012 Messages 5,326 Location Canada's Capital Nov 3, 2014 #10 I don't have a table saw or a chop saw so I just used what i had.
