I have an idea for a gantry crane and I'd like opinions on if it's safe/a good idea. I need something to pull engines from cars and stands, I won't be lifting more than about 700 pounds. I'm thinking that I could get two Horror Freight 2 ton under-hoist stands and securely mount a beam between them. Then I could hook a chain hoist to the beam, roll a car under it, pull the engine, roll the car back out, and set the engine on a stand. Assuming the beam was very securely mounted and thick enough, do you think this would work? The stands are rated at 4000lbs each, I'd be lifting at maximum less than a quarter of that. I've never seen anyone do this before, I want to make sure that there's not a safety reason for that.
Thank you
Thank you
