rickjames8
Hello all,
I recently bought a 20'wide by 19'long carport with the intention of enclosing it. I'd like to post my plans here, and get comments from others on what they might do differently, or validate my ideas.
When I ordered my carport, I upgraded to the 12ga steel to support the weight of the walls I intended to put on. The carport is attached firmly to the ground with rebar in some parts, and bolts in others.
My plan is as follows:
Re-inforce the back with a 4x4 in the center of the wall (not yet built)
Re-inforce the center of the carport with a 4x4 as well
Install two 4x4s in the front, one on either side of where the 17'wide garage door would go.
All of the reinforcing would be to handle the snow, although we typically dont get much here.
Then frame out the rear wall and the front gable with aluminum 2x4's. The header bar at the top of the garage door would be wood 2x4 as it would show.
Then cover the entire thing with 7/16 OSB sheathing, using self-drilling hex-head screws and washers.
Install flashing around the base to direct water away.
Then cover all of that with vinyl siding.
I would add a vent to the top of the rear gable.
I would be adding a doors and a couple windows, framing them in using the aluminum framing.
Comments?
Comments?
