stealthmagic27
Need to replace this 1948 "Sun Ray" Steam boiler in the new home. Should i tackle this myself? Any recommedations welcome...
Replacing a boiler is something I wouldn't recommend doing yourself unless your qualifed to do so especailly a steam boiler.
Need to replace this 1948 "Sun Ray" Steam boiler in the new home. Should i tackle this myself? Any recommedations welcome...![]()
Not without extensive research would I advise anyone to tackle such a project. I second the Dan Holohan Recommendation and would advise the title "the Lost Art of Steam Heating" If you don't know what a Hartford Loop is and can't readily Identify the difference between one or two pipe sytems I would try to find an OLD-Timer who is knowledgeable that could at the very least help you. The operation of steam boilers is a far different animal than regular hydronic and all the parts are different. You can get yourself into trouble ripping out old parts that you are unsure of as some of the old one pipe sytems have complicated vapor traps that I would be very surprised you would be able to replace once removed and discarded.... We have come a long way since the good ol days when Steam was new, but lets not forget how many men lost their lives to a steam boiler explosion! Good Luck!
There is just way more about steam than any home owner should ever consider period !
Get a professional in there and let them do what they do best.
Problem is most of the pros who knew anything about steam are dead now.
A WELL informed DIYer may well be able to do a better job then most of the pros out there.
I replaced a twenty something year old steam boiler a few weeks ago, the "pro" who installed it had an undersized single riser with no real header all done out of copper, we redid it properly with 2 1/2" black pipe, two risers to a drop header.
Doing the research will at least give one the knowledge to pick the proper pro to do the work.
Ahh, the pleasures of cracking cast iron fittings to disconnect steam piping! That's what the oversized elles are, or should be. Cast iron.
If it is busted, no reason why you can't disconnect it and set a new one. Watch for asbestos. The guys I know soak any fire-retardant remotely suspect before removal and bagging. Not that I'd, for a minute, advocate removal of asbestos by unlicensed individuals!
Steam supply, gravity condensate return, low pressure relief valve, auto fill, low water cut-off. Elegant system in it's simplicity.
The temp of the steam is higher and the radiators are smaller -- you will not get the same output at 180 degree water.
apples and oranges
steam has two settings, on and off, & they deliver heat in a completely different fashion than a hydronic system .. a modern boiler is capable of delivering a smooth even constant temperature as needs be, instead of a massive surge of heat that tapers off until the call is triggered again
you're comparing a hot air balloon to a helicopter
Actually the on and off issue doesn't matter anymore with the new controls availible
They used a slightly different radiator .... If you take a two pipe steam system and try and run 180 water through it (the normal max temp of a modern boiler) you will not get the same Btu's out of the radiators ... on the coldest day this can be an issue. Steam is 20+% hotter.
As I said -- I currently have steam heat in my NYC apartment... and I grew up with a two pipe system.
Most residential steam systems I see don't have any pumps. Usually I only see condensate return tanks if the system is zoned and requires one.steam systems only have pumps on the return side of things
Yeah, if you have 2 pipe radiators, which means you have a return line, plug up the steam vents on the radiators and convert to hot water boiler.
Many old steam heating systems put pipes in the ground or in the slab. They can have a leak that you wouldn't notice for years, convert it to water, you have a big problem.
Also steam heating systems operate at like .5-1psi, a pipe made of of saran wrap could probably contain that, which means any pipes or radiators that aren't doing so well likely spring a leak or burst. If you've got of distance in elevation between the highest radiator and the boiler, you need higher pressure in your hot water system to actually get it up there. You could figure out the distance in elevation between the lowest point on your boiler and the top of your highest radiator, and you need .43 psi per foot of water pressure to reach the top. You could try filling the system with water or pressurized air first.
Much more stable heat with hot water, steam heat like having a million btu heater in your house turn off and on all the time. Keeps the humidity up though which is always nice. Not sure how much though.
As someone who likes to tackle everything, I don't know if I'd try a steam system.
If you upgrade to hot water, you could always pex out new supplies and returns, would give you a good opportunity to put in some zone valves so you can section off whatever part of the house you want. I have a hot water boiler and radiators in my downstairs and basement, I have 5 thermostats for the 1st floor and basement, before I added a second floor, I would only have the heat on for the bedroom at night, kick the bathroom heat on before me or the wife woke up, living room/kitchen area would only be on for the 3-4 hours we were home after work and on the weekends. Basement was scheduled to warm up on sunday's for man cave football time, Don't know how much money it saved, but the satisfaction of the principal behind it was great.
Wife had enough of eating breakfast in the cold so I had to give in. No matter how many times I asked "you really want to heat this entire area up for the 15 minutes in the morning you are in it?" yes every time. Women
I've only seen a couple like that, most of them are 24v and go out with the heat. Every once in a while I'll run across a thermopile one but they're rare.The one nice thing about steam , it doesn't care if you have electricity or not it just keeps producing heat. That is if it's set up that way.
What temperature do you run to cast iron radiators? Mine run at 180 and every system I've ever touched is between 160 and 200. Steam is even hotter then that. You just learn not to touch them after the first time.no one runs 180 degree water to cast iron rads, you'd hurt people
Boiler explosions are very rare now days , that is if the safeties are installed and maintained as required.
And the truth is steam is still a very good heating system and is still used in many large commercial buildings expecialy dry cleaners.
The reason steam is safer than it used to be is because now all the applications you listed are designed, installed, operated and overseen by licensed engineers and operators, not DIY homeowners.
Tommy
I personally don't think any DIYer should be installing heating equipment , but not much can be done about it any more. That's one of the reasons our liability insurance and equipment is expensive equipment gets installed wrong or some one does something stupid and we all pay the price.
Water htrs are a great example , some idiot was working in his bsmt cleaning car parts with gas , not to far from the gas water. He blew himself and his house up.
But of course it was the Water htr manufactors fault because there was no warning on the water about doing stupid things. True story .
