I'm in the middle of a kitchen remodel and have some floor tile to take up... anyone use one for that? I think it'd make quick work of it and my compressor/hose plenty long that I can get it into my foyer area w/o having to move anything.
I used it on my 2.3L Ranger to get out a stuck O2 sensor. Had to remove the starter to get the gun and a chisel bit in place, but caught one of the corners of the hex and went to town on it, and it came out. Nothing else would budge it.
Charles
Yes to that.I've found that pickle forks like to booger up the rubber boots on my balljoints on my Corvette. Maybe they make slimmer ones than what I've had access to.
Take a chisel bit. Make a good indention on the edge of the bolt. You can then bite that at an angle and use the hammering action to turn the bolt.
I hate when people use an air hammer with a chisel to remove fan clutches. Don't do this. It puts gauges in the nut. There are tools for this. Air hammer type and manual type clutch tools.
I use my air hammer for tons of stuff. Comes in handy for breaking rusted nuts and rusty suspension parts.
i only use mine to remove ones i replace now...after one ******* got mad that i dented his nut and damn near made us pay for a new fan clutch because of it
It doesnt effect the perfprmance of the fan but it gauges the **** out of it. If had ones people did this to that were destroyed. Couldnt put wrenches on it anymore. Honestly lisle makes a real nice fan clutch tool set for the air hammer that workes really well and isn't that expensive. My opinion on this matter and similar situations is if you can't afford to or to cheap to buy the correct tools to do a job you shouldnt do that job. I own thousands of dollars in just specialty tools alone to do specific tasks and some of these tools i will only use a handfull of times through out my career but i still own them. In order to do my job properly and efficiently.
If your to buy one should it be a truck brand one or can you skimp on one x
Sent from the sticks
The snap-on is one of the best. The new ir's are pretty good. What ever you get. Buy a long barrel and if its cheap its junk. Good air hammers arnt cheap.
